ADS111的STM32驱动程序 含配置代码以及IIC通讯驱动
12sshddnigngb
2019-9-26 16:20
内含ADS111配置代码以及IIC通讯驱动
#include "stm32f10x_lib.h"
#include "ADS1115.h"
#include "stm32f10x_i2c.h"
#ifndef __cplusplus
#endif
/*--Private Value----------------------------------------------------------*/
enum TestPort {BatVal,BatCur};
unsigned char AD_BUF[2]={0};
#define SCLH GPIOB->BSRR = GPIO_Pin_6
#define SCLL GPIOB->BRR = GPIO_Pin_6
#define SDAH GPIOB->BSRR = GPIO_Pin_7
#define SDAL GPIOB->BRR = GPIO_Pin_7
#define SCLread GPIOB->IDR & GPIO_Pin_6
#define SDAread GPIOB->IDR & GPIO_Pin_7
void I2C_GPIO_Config(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
// Configure I2C1 pins: SCL and SDA
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;//assert管脚
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
void I2C_delay(void)
{ unsigned char i=30; //
while(i)
i--;
bool I2C_Start(void)
SDAH;
I2C_delay();
SCLH;
I2C_delay();
if(!SDAread)return FALSE; //SDA线为低则总线忙,退出
SDAL;
I2C_delay();
if(SDAread)
return FALSE; //SDA线为高则总线出错,退出
SDAL;
I2C_delay();
return TRUE;
void I2C_Stop(void)
SCLL;
I2C_delay();
SDAL;
I2C_delay();
SCLH;
I2C_delay();
SDAH;
I2C_delay();
void I2C_Ack(void)
SCLL;
I2C_delay();
SDAL;
I2C_delay();
SCLH;
I2C_delay();
SCLL;
I2C_delay();
void I2C_NoAck(void)
SCLL;
I2C_delay();
SDAH;
I2C_delay();
SCLH;
I2C_delay();
SCLL;
I2C_delay();
bool I2C_WaitAck(void) //返回1有ACK,返回0无ACK
SCLL;
I2C_delay();
SDAH;
I2C_delay();
SCLH;
I2C_delay();
if(SDAread)
{ SCLL;
return FALSE;
SCLL;
return TRUE;
void I2C_SendByte(u8 SendByte) //数据从高位到低位//
u8 i=8;
while(i--)
SCLL;
I2C_delay();
if(SendByte&0x80)
SDAH;
SDAL;
SendByte<<=1;
I2C_delay();
SCLH;
I2C_delay();
SCLL;
u8 I2C_ReceiveByte(void) //数据从高位到低位//
u8 i=8;
u8 ReceiveByte=0;
SDAH;
while(i--)
ReceiveByte<<=1;
SCLL;
I2C_delay();
SCLH;
I2C_delay();
if(SDAread)
ReceiveByte|=0x01;
SCLL;
return ReceiveByte;
* 名 称: ADS1115_Init
* 功 能: 初始化ADS1115
* 入口参数:id:设备地址;write_address寄存器 ;byte1:高字节配置;byte2:低字节 最高转换速度
* 出口参数: 无
* 说 明: 完成ADS1115的配置寄存器的初始化
void ADS1115_Init(unsigned char id,unsigned char write_address,unsigned char byte1,unsigned char byte2)
while(!I2C_Start());
I2C_SendByte(id);//写器件地址
while(!I2C_WaitAck());
I2C_SendByte(write_address);//寄存器地址
I2C_SendByte(byte1);//发送数据
I2C_SendByte(byte2);//发送数据
I2C_Stop();
I2C_delay();
I2C_delay();
* 名 称: I2C_AD1115_Point
* 功 能: 指向ADS1115内部特定的寄存器
* 入口参数: id:设备地址;write_address寄存器
* 出口参数: 无
* 说 明: 指向ADS1115内部特定的寄存器
void I2C_AD1115_Point(unsigned char id,unsigned char write_address)
//产生起始条件
//向设备发送设备地址
//等待ACK
I2C_SendByte(write_address);//发送数据
//寄存器地址
I2C_Stop();
//产生结束信号
* 名 称: I2C_Read2
* 功 能: 读ADS1115转换结果
* 入口参数: id:设备地址;read_address寄存器地址
* 出口参数: 无
* 说 明: 转换的值放在BUF【2】
void I2C_Read2(unsigned char id, unsigned char read_address)
//产生起始条件
//发送地址
//等待ACK
AD_BUF[0] = I2C_ReceiveByte();
I2C_Ack();
AD_BUF[1] = I2C_ReceiveByte();
I2C_NoAck();
I2C_Stop();
* 名 称: StartChannel
* 功 能: 选择通道测量
* 入口参数: 通道0、1、2、3
* 出口参数: 采样值
* 说 明: 完成ADS1115的采样工作
s16 Out,AIN2,AIN1,AIN3,AIN0;
s16 AD_Buff[4];
int temp=0;
float StartChannlel(char Channel)
float AD_Val=0;
if(Channel==0)
{ //First (1001000)Address+0; Second :Point to the Config resgister BatVal
ADS1115_Init(0x90,0x01,0xc2,0xe0); //量程4.096;Continuous conversionmode;AIN1
//860SPS;
Out=AIN0-AIN1;
if(Channel==1)
ADS1115_Init(0x90,0x01,0xd2,0xe0); //量程1.024;Continuous conversionmode;AIN3 BatCur
//860SPS;
Out=AIN2-AIN3;//00110110
if(Channel==2)
ADS1115_Init(0x90,0x01,0xe2,0xe0); //量程4.096;Continuous conversionmode;GND
//860SPS;
if(Channel==3)
ADS1115_Init(0x90,0x01,0xf2,0xe0); //量程4.096;Continuous conversionmode;GND
//860SPS;
while(GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_4));
I2C_AD1115_Point(0x90,0x00);
I2C_delay();
I2C_delay();
I2C_Read2(0x91,0x00);
temp=(AD_BUF[0] << 8) | AD_BUF[1];
// AD_Val=4096*temp/32768.0;
AD_Val=temp;
if(Channel==0)
AD_Buff[0]=AD_Val;
if(Channel==1)
AD_Buff[1]=AD_Val;
if(Channel==2)
AD_Buff[2]=AD_Val;
if(Channel==3)
AD_Buff[3]=AD_Val;
return AD_Val;
ADS115.rar
(610.13 KB, 下载次数: 39)
2019-9-26 16:19 上传
点击文件名下载附件
下载积分: 黑币 -5
