标题: AES256加密算法原理图 [打印本页]
作者: IDKT    时间: 2019-9-27 15:29
标题: AES256加密算法原理图
General Description
The IDKT is a family of high performance AES256 CODEC with cipher memory device providing 2K Bytes of user memory.
Features
l A illegal Copy Protection IC
l Random Stream Cipher for Interface
l 2K Bytes Secure EEPROM
l I2C or 1-Wire Communication Protocol Support 40-bit Unique serial number
l Support MTP/OTP User Area
l Only Increment Counting Function
  for Inkjet Printer and Cartridge
l Input Voltage Range 1.8V ~ 3.6V
l Power On/Off for Low Power Mode
l Available Package SOT23/8SOP/TDFN
Benefits
l Protection illegal reproduction
l Mass production control
l Receiving royalty from SW/HW
Applications
l Authorization using Cipher EEPROM
l Contents Encryption and Decryption
l Network Authorization
l Anti-clone protection
l Secure boot
l Printer cartridge, Water purifier
l All of Electronic Systems Using
  MCU/ CPU / AP
Authorization Flow
