LoRa官方驱动程序 SX12xxDrivers
zh1356
2019-10-7 19:04
官方驱动源程序如下:
* \file main.c
* \brief Ping-Pong example application on how to use Semtech's Radio
* drivers.
* \version 2.0
* \date Nov 21 2012
* \author Miguel Luis
#include <string.h>
#include <stdint.h>
#include <stdbool.h>
#include "platform.h"
#include "led.h"
#if USE_UART
#include "uart.h"
#endif
#include "radio.h"
#define BUFFER_SIZE 9 // Define the payload size here
static uint16_t BufferSize = BUFFER_SIZE; // RF buffer size
static uint8_t Buffer[BUFFER_SIZE]; // RF buffer
static uint8_t EnableMaster = true; // Master/Slave selection
tRadioDriver *Radio = NULL;
const uint8_t PingMsg[] = "PING";
const uint8_t PongMsg[] = "PONG";
* Manages the master operation
void OnMaster( void )
uint8_t i;
switch( Radio->Process( ) )
case RF_RX_TIMEOUT:
// Send the next PING frame
Buffer[0] = 'P';
Buffer[1] = 'I';
Buffer[2] = 'N';
Buffer[3] = 'G';
for( i = 4; i < BufferSize; i++ )
Buffer[i] = i - 4;
Radio->SetTxPacket( Buffer, BufferSize );
break;
case RF_RX_DONE:
Radio->GetRxPacket( Buffer, ( uint16_t* )&BufferSize );
if( BufferSize > 0 )
if( strncmp( ( const char* )Buffer, ( const char* )PongMsg, 4 ) == 0 )
// Indicates on a LED that the received frame is a PONG
LedToggle( LED_GREEN );
Buffer[0] = 'P';
Buffer[1] = 'I';
Buffer[2] = 'N';
Buffer[3] = 'G';
// We fill the buffer with numbers for the payload
Buffer[i] = i - 4;
else if( strncmp( ( const char* )Buffer, ( const char* )PingMsg, 4 ) == 0 )
{ // A master already exists then become a slave
EnableMaster = false;
LedOff( LED_RED );
break;
case RF_TX_DONE:
// Indicates on a LED that we have sent a PING
LedToggle( LED_RED );
Radio->StartRx( );
break;
default:
break;
* Manages the slave operation
void OnSlave( void )
uint8_t i;
case RF_RX_DONE:
// Indicates on a LED that the received frame is a PING
// Send the reply to the PONG string
Buffer[0] = 'P';
Buffer[1] = 'O';
Buffer[2] = 'N';
Buffer[3] = 'G';
Buffer[i] = i - 4;
break;
case RF_TX_DONE:
// Indicates on a LED that we have sent a PONG
Radio->StartRx( );
break;
default:
break;
* Main application entry point.
int main( void )
BoardInit( );
Radio = RadioDriverInit( );
Radio->Init( );
Radio->StartRx( );
while( 1 )
if( EnableMaster == true )
OnMaster( );
OnSlave( );
#if( PLATFORM == SX12xxEiger ) && ( USE_UART == 1 )
UartProcess( );
uint8_t data = 0;
if( UartGetChar( &data ) == UART_OK )
UartPutChar( data );
#endif
#ifdef __GNUC__
return 0;
#endif
SX12xxDrivers-V2.1.0.7z
(820.95 KB, 下载次数: 46)
2019-10-7 23:04 上传
点击文件名下载附件
下载积分: 黑币 -5
