标题: 数码管彩灯数字和变换 含单片机代码 [打印本页]
作者: 我儿是4楼    时间: 2019-10-9 17:12
这是做的数码管我做了一个下午时间
里面有单片机的源代码
keil做的程序
有proteus做的仿真
  1. #include<reg51.h>
  2. #define uint unsigned int
  4. #define SEG P0
  5. sbit PB1=P2^0;
  6. sbit PB2=P2^2;
  7. uchar TAB[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x83,0xf8,0x80,0x98};
  8. uchar TAB1[]={0x90,0xf8,0x90,0x92,0xa4,0xc0,0xf9,0xb0,0xf9,0x99};
  9. uchar TAB2[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
  10. void delay_1ms(uint t)
  11. {
  12. uint k;
  13. while(--t)
  14. for(k=0;k<600;k++);
  15. }
  16. main()
  17. {
  18. unsigned char i;
  19.   {
  20.                  for(i=0;i<10;i++)
  21.                  {
  22.                   SEG=TAB[i];
  23.                   delay_1ms(500);
  24.                   if(PB1==0)
  25.                    {
  26.                         for(i=0;i<10;i++)
  27.                      {
  28.                   SEG=0xff;
  29.                   delay_1ms(800);
  30.                   SEG=TAB1[i];
  31.                   delay_1ms(800);
  32.                      }
  33.                         }
  34.                    if(PB2==0)
  35.                          {
  36.                            for(i=0;i<12;i++)
  37.                            {
  38.                            SEG=TAB2[i];
  39.                            delay_1ms(200);
  40.                            }
  41.                          }
  42.
  43.                  }
  44.
  45.   }
  46. }
数码管1.zip (346.4 KB, 下载次数: 3)
