±êÌâ: arduino+moc33021+bta16ΪʲôɶֻÓа벨¿ØÖÆ£¬Çó´óÀнâÒÉ [´òÓ¡±¾Ò³]
×÷Õß: jzli2019    ʱ¼ä: 2019-11-1 17:54
void up()
  digitalWrite(12, HIGH);
  delayMicroseconds(5000);
  digitalWrite(12, LOW);
  delayMicroseconds(1000);
void setup() {
  pinMode(2, INPUT);
  pinMode(12, OUTPUT);
  // put your setup code here, to run once:
  attachInterrupt(0, up, RISING);
void loop() {
  // put your main code here, to run repeatedly:
  delay(100);
Õâ¸öÊÇarduino´úÂ룬¼ì²âµ½¹ýÁãºóÑÓʱ5ms¿ØÖÆmoc3021¿ªÍ¨¡£
²»ÖªµÀΪʲôֻÓÐÔÚ220vµÄ¸º°ë²¨ÄÜ¿ªÍ¨¿É¿Ø¹è£¬ÕýµÄ°ë²¨Ò»µã·´Ó¦¶¼Ã»ÓУ¬¿É¿Ø¹è´¥·¢µç·ÊDzο¼µÄmoc3021ÊÖ²áÍÆ¼öµç·£¬ÊDz»ÊÇproteus·ÂÕæÔª¼þÓÐÎÊÌ⣿moc3021£¿bta16-600bw£¿
Arduino 328.rar
92.11 KB, ÏÂÔØ´ÎÊý: 12
proteusÏîÄ¿Îļþ
×÷Õß: jzli2019    ʱ¼ä: 2019-11-4 09:37
ûÓÐÈËÂð£¿
×÷Õß: taotie    ʱ¼ä: 2019-11-4 10:31
jzli2019 ·¢±íÓÚ 2019-11-4 09:37
ûÓÐÈËÂð£¿
ÕâÊÇProteus 8 ÖеÄÀý³Ì¿´Ò»¿´°É
/* Main.ino file generated by New Project wizard
* Created:   mer ago 22 2018
* Processor: Arduino Uno
* Compiler:  Arduino AVR
int AC_LOAD = 3;    // Output to Opto Triac pin
int dimming = 128;  // Dimming level (0-128)  0 = ON, 128 = OFF
void setup()
  pinMode(AC_LOAD, OUTPUT);// Set AC Load pin as output
  attachInterrupt(0, zero_crosss_int, RISING);  // Choose the zero cross interrupt # from the table above
//the interrupt function must take no parameters and return nothing
void zero_crosss_int()  //function to be fired at the zero crossing to dim the light
  // Firing angle calculation : 1 full 50Hz wave =1/50=20ms
  // Every zerocrossing thus: (50Hz)-> 10ms (1/2 Cycle)
  // For 60Hz => 8.33ms (10.000/120)
  // 10ms=10000us
  // (10000us - 10us) / 128 = 75 (Approx) For 60Hz =>65
  int dimtime = (75*dimming);    // For 60Hz =>65
  delayMicroseconds(dimtime);    // Wait till firing the TRIAC
  digitalWrite(AC_LOAD, HIGH);   // Fire the TRIAC
  delayMicroseconds(10);         // triac On propogation delay (for 60Hz use 8.33)
  digitalWrite(AC_LOAD, LOW);    // No longer trigger the TRIAC (the next zero crossing will swith it off) TRIAC
void loop()  {
  for (int i=5; i <= 128; i++){
    dimming=i;
    delay(10);
×÷Õß: taotie    ʱ¼ä: 2019-11-4 10:51
¼ì²âµ½¹ýÁãºóÑÓʱ5ms¿ØÖÆmoc3021¿ªÍ¨£¿£¿£¿£¿
ÓÃ10msÊÔÒ»ÊÔ~~
×÷Õß: jzli2019    ʱ¼ä: 2019-11-4 14:33
taotie ·¢±íÓÚ 2019-11-4 10:31
Õâ¸öÀý×ÓÃû³Æ½Ðʲô£¬ÎÒÏë¿´¿´ÍêÕûÏîÄ¿
×÷Õß: jzli2019    ʱ¼ä: 2019-11-4 14:44
¿ÉÒÔ¿´µ½µ¥Æ¬»ú´¥·¢ÐźÅÓ¦¸ÃÊÇûÎÊÌâµÄ£¬µ«ÊÇÖ»Óиº°ë²¨¿É¿Ø¹è¿ªÍ¨ÁË
×÷Õß: taotie    ʱ¼ä: 2019-11-4 16:24
jzli2019 ·¢±íÓÚ 2019-11-4 14:33
Arduino Dimming 230V AC
×÷Õß: taotie    ʱ¼ä: 2019-11-4 17:12
°´ÄãµÄ³ÌÐò·ÂÕæÃ»µÃÎÊÌâ¡£¡£
×÷Õß: jzli2019    ʱ¼ä: 2019-11-4 18:02
taotie ·¢±íÓÚ 2019-11-4 17:12
´óÀУ¬ÎÒ°Ñproteus8.7Ð¶ÔØÁËÖØÐÂ×°ÁËproteus8.9£¬ÏÖÔÚÄ£ÄâҲûÎÊÌâÁË¡£¡£¡£ºÜĪÃûÆäÃî°¡
×÷Õß: jzli2019    ʱ¼ä: 2019-11-4 18:03
ÄãÓõÄÊÇÄĸö°æ±¾£¬ÎҸоõ¾ÍÊǰ汾²»¶Ôµ¼Öµġ£¡£¡£
×÷Õß: taotie    ʱ¼ä: 2019-11-5 13:01
jzli2019 ·¢±íÓÚ 2019-11-4 18:03
ºÇºÇ8.8
»¶Ó­¹âÁÙ (http://www.51hei.com/bbs/) Powered by Discuz! X3.1
