标题: 51单片机音乐盒元件清单与源程序 [打印本页]
作者: z1160130751    时间: 2019-11-9 20:23
一.材料
发光二极管                                  18个;
按键                                              4个;
STC89c52单片机                        1个;
单片机插座                                  1个;
11.0592MHZ的晶振                  1个;
22pf电容*2,10uf电容              1个;
喇叭                                              1个;
三极管                                          1个;
滑动变阻器                                  1个;
电阻10k                                       1个;
电阻5.1k           1个;
电源
杜邦线若干;
#include <reg51.h>
sbit speaker = P3^1;
sbit key0 = P2^0;
sbit key1 = P2^1;
sbit key2 = P2^2;
sbit key3 = P2^3;
unsigned char k, i;
unsigned char timer0h, timer0l, time ,num ,tempi,tempstop,tempan,temptime;
unsigned char code table[]={//我做的数码管 数字显示
0x3f,0x30,0xed,0x79,
0x72,0x5b,0x5f};
unsigned char code table[]={  //数码管 数字显示
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
//---------------------------------1 2 3 4 5 6 7音调
code unsigned char FREQH[] = {           //TH0部分
    0xF2, 0xF3, 0xF5, 0xF5, 0xF6, 0xF7, 0xF8,       //低音1234567
    0xF9, 0xF9, 0xFA, 0xFA, 0xFB, 0xFB, 0xFC, 0xFC,   //中
    0xFC, 0xFD, 0xFD, 0xFD, 0xFD, 0xFE,              //高
    0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFF    //超高
code unsigned char FREQL[] = {           //TL0部分
    0x42, 0xC1, 0x17, 0xB6, 0xD0, 0xD1, 0xB6,
    0x21, 0xE1, 0x8C, 0xD8, 0x68, 0xE9, 0x5B, 0x8F,
    0xEE, 0x44, 0x6B, 0xB4, 0xF4, 0x2D,
    0x47, 0x77, 0xA2, 0xB6, 0xDA, 0xFA, 0x16
code unsigned char song[][150]={    //歌曲
{3,2,2, 3,2,2, 3,2,2, 1,2,1, 3,2,2, 0,0,0, 5,2,2, 0,0,0,
5,1,2, 0,0,0, 1,2,1, 0,0,0, 5,1,1, 0,0,0, 3,1,2, 0,0,0,
6,1,2, 7,1,2, 7,1,2, 6,1,2, 5,1,2, 3,2,2, 5,2,1, 6,2,1,
0,0,0, 4,2,1, 5,2,1, 0,0,0, 3,2,1, 0,0,0, 1,2,1, 2,2,1,
7,1,2, 0,0,0, 1,2,2, 0,0,0, 5,1,1, 0,0,0, 0,0,0, 3,1,1,
0,0,0, 6,1,2, 7,1,2, 0,0,0, 7,1,2, 6,1,2, 5,1,2, 3,2,2, 0,0,100
{6, 2, 3,  5, 2, 1,  3, 2, 2,  5, 2, 2,  1, 3, 2,  6, 2, 1,  5, 2, 1,
//一个音符有三个数字。前为第几个音、中为第几个八度、后为时长(以半拍为单位)。
//6, 2, 3 分别代表:6, 中音, 3个半拍;
//5, 2, 1 分别代表:5, 中音, 1个半拍;
//3, 2, 2 分别代表:3, 中音, 2个半拍;
//5, 2, 2 分别代表:5, 中音, 2个半拍;
//1, 3, 2 分别代表:1, 高音, 2个半拍;
6, 2, 4, 3, 2, 2, 5, 2, 1, 6, 2, 1, 5, 2, 2, 3, 2, 2, 1, 2, 1,
6, 1, 1, 5, 2, 1, 3, 2, 1, 2, 2, 4, 2, 2, 3, 3, 2, 1, 5, 2, 2,
5, 2, 1, 6, 2, 1, 3, 2, 2, 2, 2, 2, 1, 2, 4, 5, 2, 3, 3, 2, 1,
2, 2, 1, 1, 2, 1, 6, 1, 1, 1, 2, 1, 5, 1, 6, 0, 0, 100},
{6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 0,0,100},
{0,0,1, 0,0,100},
void delay(unsigned char t)     //节拍
unsigned char t1;
unsigned long t2;
for(t1 = 0; t1 < t; t1++)
  for(t2 = 0; t2 < 8000; t2++);
TR0 = 0;
void delaya(unsigned char t)     //节拍
unsigned char t1;
unsigned long t2;
  for(t2 = 0; t2 < 2000; t2++);
TR0 = 0;
void delay1(int z)   //延迟z ms
int i,j;
for(i=0;i<110;i++)
  for(j=0;j<z;j++);
void an()  //按键检测
P2=0xff;
if(key1==0||key2==0||key3==0)
  delay1(10);
  if(key1==0)
   num++;
   if(num==4)
     num=0;
   i=0;
   time=0;
  if(key2==0)
   num--;
   if(num==-1)
     num=3;
   i=0;
   time=0;
  if(key3==0)
   tempstop=!tempstop;
  while(!key1||!key2||!key3);
  delay1(5);
void an()  //按键检测
P2=0xff;
tempan=P2;
tempan=tempan&0x0f;
while(tempan!=0x0f)
  delay1(5);
  tempan=P2;
  tempan=tempan&0x0f;
  while(tempan==0x0f);
  switch(tempan)
   case 0x0e:
    num++;
    if(num==4)
      num=0;
    i=0;
    time=0;
    break;
   case 0x0d:
    num--;
    if(num==-1)
      num=3;
    i=0;
    time=0;
    break;
   case 0x0b:
    tempstop=!tempstop;
    break;
   case 0x07:
    temptime=!temptime;
    break;
  while(tempan!=0x0f)
   tempan=P2;
   tempan=tempan&0x0f;
   delay1(5);
void main(void)
tempi=1;
TMOD = 1;
ET0 = 1;
EA = 1;
  if(song[num][i+2]==100)
   i=0;
  k = song[num]+7*(song[num][i + 1]-1);
  timer0h = FREQH[k];
  timer0l = FREQL[k];
  time = song[num][i + 2];
  if(tempi==1)
  i += 3;
  TH0 = timer0h;
  TL0 = timer0l;
  TR0 = 1;
  if(!temptime)
   delay(time);
   delaya(time);
  P1=table[num+1];
  while(tempstop)
   an();
void t0int() interrupt 1
    TR0 = 0;
    speaker = !speaker;
    TH0 = timer0h;
    TL0 = timer0l;
    TR0 = 1;
  an();
作者: 517538964    时间: 2021-3-28 22:41
楼主  有仿真图吗   还有材料还需要买什么吗  我想做出来  谢谢
