串口调试助手向串口一发送命令,串口1把命令写到串口2,再把数据显示到串口一
17851000590
2019-12-6 16:09
#include "reg51.h"
#include "intrins.h"
#define FOSC 11059200UL
#define BRT (65536 - FOSC / 115200 / 4)
#define BRT2 (65536 - FOSC / 9600 / 4)
sfr AUXR = 0x8e;
sfr T2H = 0xd6;
sfr T2L = 0xd7;
sfr S2CON = 0x9a;
sfr S2BUF = 0x9b;
sfr IE2 = 0xaf;
bit busy;
char wptr;
char rptr;
char buffer[16];
bit busy2;
char wptr2;
char rptr2;
char buffer2[16];
void UartIsr() interrupt 4 using 1
if (TI)
TI = 0;
busy = 0;
if (RI)
RI = 0;
buffer2[wptr2++] = SBUF;
wptr2 &= 0x0f;
void Uart2Isr() interrupt 8 using 1
if (S2CON & 0x02)
S2CON &= ~0x02;
busy2 = 0;
if (S2CON & 0x01)
S2CON &= ~0x01;
buffer[wptr++] = S2BUF;
wptr &= 0x0f;
void UartInit()
SCON = 0x50;
TMOD = 0x00;
TL1 = BRT;
TH1 = BRT >> 8;
TR1 = 1;
AUXR |= 0x40;
wptr = 0x00;
rptr = 0x00;
busy = 0;
void Uart2Init()
S2CON = 0x50;
T2L = BRT2;
T2H = BRT2 >> 8;
AUXR |= 0x14;
wptr2 = 0x00;
rptr2 = 0x00;
busy2 = 0;
void UartSend(char dat)
while (busy);
busy = 1;
SBUF = dat;
void Uart2Send(char dat)
while (busy);
busy2 = 1;
S2BUF = dat;
void UartSendStr(char *p)
while (*p)
UartSend(*p++);
void Uart2SendStr(char *p)
while (*p)
Uart2Send(*p++);
UartInit();
Uart2Init();
IE2 = 0x01;
ES = 1;
EA = 1;
UartSendStr("Uart Test !\r\n");
Uart2SendStr("Uart2 Test !\r\n");
while (1)
if (rptr != wptr)
UartSend(buffer[rptr++]);
rptr &= 0x0f;
if (rptr2 != wptr2)
Uart2Send(buffer2[rptr2++]);
rptr2 &= 0x0f;
//--------------------结束-以上代码可以运行--------------------------------
while (1)
17851000590
2019-12-6 20:44
stc8f2k08s2 说明上写着支持双串口。我在stc-isp上看到的范例单独串口1实现,和串口2实现。 这里需求需要 数据 通过串口1接收 ,在通过串口2发出去。
我想把下面的的共能和在一起,同时支持串口1的收发,串口2的收发。 上面的两段代码 就 AUXR 的值不同。合在一起AUXR冲突。
向大家请教。
