单片机流水灯编译错误error C161: 'Z': formal parameter ignoredTarget not created
郭爱艳
2019-12-21 02:23
B.C(50): error C161: 'Z': formal parameter ignoredTarget not created 编译错误!
/* 程序名:可控流水灯 */
/* 功能:实现流水灯的方向、速度、亮度控制 */
/* 硬件:P2 接开关,P1接LED ,数码管显示。 */
#include<reg52.h>
#include <intrins.h>
sbit K1=P2^0; //方向
sbit K2=P2^1; //加速
sbit K3=P2^2; //减速
sbit K4=P2^3; //加亮
sbit K5=P2^4; //变暗
unsigned char Speed,LED;
unsigned int tCount=0;
unsigned char Idx; //速度取值索引
unsigned char DelayMS;
bit Dirtect=1; //滚动方向
char duty=10; //占空比
unsigned int code sTable[]={0,1,3,7,9,15,30,50,100,200,230,280,300,350}; //调速表
unsigned char code seg_table[ ]={0xc0,0xf9,0xa4,0xb0,
0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,
0xc6,0xa1,0x86,0x8e
}; //数组缺少 [ ] ,要加code
void delay_key(int i)
for (i=0;i<0;i++);
P1=0x00;
unsigned char delay_key(Z);
void delay_key(unsigned int Z )
while(Z--) for(i=0;i<9;i++);
P1=seg_table[i];
i=(i+1)%10;/*显示0-9*/
delay_key(200);
void InitTimer0_Timer1(void);
void delay(unsigned int x)
unsigned char i;
while(x--) for(i=0;i<20;i++);
unsigned char GetKey(void)
unsigned char K;
if(P2==0xFF) return 0;
delay(10);
switch(P2)
case 0xFE:K=1;break;
case 0xFD:K=2;break;
case 0xFB:K=3;break;
case 0xF7:K=4;break;
case 0xEF:K=5;break;
default: K=0;break;
while(P2!=0xFF); //等待释放按键
return K;
void KeyProcess(unsigned char Key)
switch(Key)
case 1:Dirtect=~Dirtect;break; //方向
case 2:if(Idx>1) Speed=sTable[--Idx];break;//加速
case 3:if(Idx<15) Speed=sTable[++Idx];break;//减速
case 4:duty++;if(duty>=20) duty=20;break; //加亮
case 5:duty--;if(duty<=0) duty=1; break;//变暗
unsigned char Key;
P0=P2=P1=0xFF;
Idx=4;
Speed=sTable[Idx];
IP=0x02; //中断优先级
InitTimer0_Timer1();
LED = 0xfe;
P0 = LED;
Key=GetKey();
if(Key!=0) KeyProcess(Key);
/* 定时器0和定时器1初始化 */
TMOD = 0x20;
TH1 = 0x06;
TL1 = 0x06;
EA = 1;
ET0 = 1;
TR0 = 1;
ET1 = 1;
TR1 = 1;
/* 定时器中断函数 */
void timer0(void) interrupt 1
if(++tCount<Speed) return;
tCount=0;
if(Dirtect==1) LED = _cror_(LED,1); //循环右移1位,点亮下一个LED
else LED=_crol_(LED,1);
P0=LED;
void Timer1(void) interrupt 3 //调节占空比
static char t=0;
t++;
if(t==20)
t=0;
P0=(0x00|LED);
if(duty==t) P0=0xFF;
xpf.
2019-12-21 18:35
#include <reg52.h>
sbit beep=P1^5;
typedef unsigned int uint;
void delay1(uint n)
uint i;
while (n--)
for(i=0;i<125;i++);
{ l
uint i;
P2=0x80;
while (1)
for(i=0;i<7;i++)
P2=_cror_(P2,1);
delay1(500);
for(i=0;i<7;i++)
f
P2= crol _(P2,1);
delay1(500);
beep=!beep;
delay1(1000);
tyrl800
2019-12-22 18:08
去掉void delay_key(int i)
for (i=0;i<0;i++);
P1=0x00;
P1=seg_table[i];
delay_key(200);
学海无涯.
2019-12-22 18:55
这个程序可以吧
(853.69 KB, 下载次数: 57)
下载附件
2019-12-22 18:55 上传
