stm32f103开发板RC522读写程序亲测可用
shuaikang
2019-12-23 11:36
#include "stm32f10x.h"
#include "./usart/bsp_usart.h"
#include "./lcd/bsp_ili9341_lcd.h"
#include "./flash/bsp_spi_flash.h"
#include "./SysTick/bsp_SysTick.h"
#include "rc522_config.h"
#include "rc522_function.h"
#include <stdbool.h>
#define READ_WRITE_ENABLE 1 // 1:使能读写卡测试相关代码 0:禁用读写卡测试相关代码
void IC_CMT ( uint8_t * UID, uint8_t * KEY, uint8_t RW, uint8_t * Dat );
* @brief IC测试函数
* @param 无
* @retval 无
uint8_t buffer[100];
uint8_t buff2[]={0xFF ,0xFF, 0xFF, 0xFF, 0xFF, 0xFF}; // 卡A密钥
uint8_t buff3[]={0x55 ,0xBA, 0xA9, 0x89, 0x50 ,0xBA, 0xA9, 0x89, 0x50 ,0xBA, 0xA9, 0x89, 0x50 ,0xBA, 0xA9, 0x89}; // 写入的数据
void IC_test ( void )
char cStr [ 30 ];
uint8_t ucArray_ID [ 4 ]; /*先后存放IC卡的类型和UID(IC卡序列号)*/
uint8_t ucStatusReturn; /*返回状态*/
static uint8_t ucLineCount = 0;
int i;
while ( 1 )
/*寻卡*/
if ( ( ucStatusReturn = PcdRequest ( PICC_REQALL, ucArray_ID ) ) != MI_OK )
/*若失败再次寻卡*/
ucStatusReturn = PcdRequest ( PICC_REQALL, ucArray_ID );
if ( ucStatusReturn == MI_OK )
/*防冲撞(当有多张卡进入读写器操作范围时,防冲突机制会从其中选择一张进行操作)*/
if ( PcdAnticoll ( ucArray_ID ) == MI_OK )
sprintf ( cStr, "The Card ID is: %02X%02X%02X%02X",
ucArray_ID [ 0 ],
ucArray_ID [ 1 ],
ucArray_ID [ 2 ],
ucArray_ID [ 3 ] );
printf ( "%s\r\n",cStr );
if ( ucLineCount == 0 )
LCD_SetTextColor(RED);
ILI9341_DispStringLine_EN(LINE(ucLineCount) , (char* )cStr );
#if READ_WRITE_ENABLE
/*******************卡片扇区读写测试****************************/
buff3[0]++;
printf ("开始读写卡测试:\n");
IC_CMT(ucArray_ID, buff2, 0, buff3); // 写卡
IC_CMT(ucArray_ID, buff2, 1, buffer); // 读卡
printf ("读到的数据为:\n");
for( i=0; i<16; i++)
printf ("0x%X ", buffer[i]); // 打印读到的数据
printf ("\n");
memset(buffer, 0, sizeof(buffer));
IC_CMT(ucArray_ID, buff2, 1, buffer); // 需要在读一次下次再能写进去(不知道为什么这样,应该是这样能改变某种模式吧)
/*******************卡片扇区读写测试 END****************************/
#endif
ucLineCount ++;
if ( ucLineCount == 17 ) ucLineCount = 0;
char PcdComMF522 ( uint8_t ucCommand,
uint8_t * pInData,
uint8_t ucInLenByte,
uint8_t * pOutData,
uint32_t * pOutLenBit ) ;
uint8_t buff[] = {0x06, 0x61, 0x1, 0x2, 0x3, 0x4 ,0x6, 0x1, 0x2, 0x3, 0x4};
uint32_t bufferlen;
* @brief 主函数
* @param 无
* @retval 无
int main(void)
/*滴答时钟初始化*/
SysTick_Init ();
/*LCD 初始化*/
ILI9341_Init ();
/* USART config */
USART_Config();
/*RC522模块所需外设的初始化配置*/
RC522_Init ();
printf ( "WF-RC522 Test\n" );
/*其中0、3、5、6 模式适合从左至右显示文字,*/
ILI9341_GramScan ( 6 );
LCD_SetFont(&Font8x16);
LCD_SetColors(BLACK,BLACK);
/* 清屏,显示全黑 */
ILI9341_Clear(0,0,LCD_X_LENGTH,LCD_Y_LENGTH);
/********显示字符串示例*******/
ILI9341_DispStringLine_EN(LINE(18),
(char* )"Please put the IC card on WF-RC522 antenna area ...");
LCD_SetTextColor(YELLOW);
PcdReset ();
/*设置工作方式*/
M500PcdConfigISOType ( 'A' );
/*IC卡检测 */
IC_test ();
/* ------------------------------------------end of file---------------------------------------- */
/*设置工作方式*/
while ( 1 )
/*IC卡检测*/
IC_test ();
F103_霸道开发板.7z
2019-12-23 13:27 上传
点击文件名下载附件
下载积分: 黑币 -5
223.51 KB, 下载次数: 83, 下载积分: 黑币 -5
