单片机+Proteus仿真四路抢答器程序
luozhao
2019-12-25 21:45
(31.87 KB, 下载次数: 54)
下载附件
2019-12-25 21:44 上传
#include<reg52.h>
sbit RS = P2^0;
sbit RW = P2^1;
sbit EN = P2^2;
sbit K0 = P3^0;
sbit K1 = P1^0;
sbit K2 = P1^1;
sbit K3 = P1^2;
sbit K4 = P1^3;
sbit K5 = P3^1;
sbit K6 = P2^3;
sbit K7 = P2^4;
sbit K8 = P3^4;
sbit Buzz = P3^7;
uint cnt = 0;//记录中断次数
uint cnt1= 0;
uint sec = 20;//记录倒计时
uchar num = 0;//记录抢答选手
uchar flag = 1;//抢答标志
uchar s_flag = 0;//开始标志
uchar e_flag = 0;//结束标志
uchar score[4]={0};
void init1602();
void Lcdshow(uchar x,uchar y,uchar *str);
void KeyScan();
void Keycontrol() ;
void Judge();
uchar IntToString(uchar *str, int dat);
uchar str1[12];
uchar str2[12];
uchar len,len1;
EA = 1;
ET0 = 1;
TMOD = 0x11;//打开定时器T0,T1
TR0 = 0;
TH0 = 0xFC;
TL0 = 0x67;
TR1 = 0;
TH1 = 0xFC;
TL1 = 0x67;
ET1 = 1;
init1602();
Lcdshow(0,0,str1);
Keycontrol();
KeyScan();
len = IntToString(str1,sec);
len1= IntToString(str2,num);
if(e_flag==0)
Lcdshow(0,0,"Time:");
Lcdshow(6,0,str1);
if(num!=0&&e_flag==0&&flag==0)//没有结束且有人按下按键
Lcdshow(0, 1, "answerer:");
Lcdshow(9, 1, str2);
if(e_flag==1)
Judge();
/*等待液晶准备*/
void Lcdready()
uchar sta;
P0 = 0xFF;
RS = 0;
RW = 1;
do
EN = 1;
sta = P0;//读取状态字
EN = 0;
}while(sta & 0x80);
/* 向 LCD1602 液晶写入命令,cmd-待写入命令值 */
void WriteCmd(uchar cmd)
Lcdready();
RS = 0;
RW = 0;
P0 = cmd;
EN = 1;
EN = 0;
/* 向 LCD1602 液晶写入数据,dat-待写入数据 */
void WriteData(uchar dat)
Lcdready();
RS = 1;
RW = 0;
P0 = dat;
EN = 1;
EN = 0;
/* 设置显示 RAM 起始地址(x,y)-对应屏幕上的字符坐标 */
void Lcdaddr(uchar x,uchar y)
uchar m;
if(y==0)
m = 0x00+x; //第一行字符地址从 0x00 起始
m = 0x40+x; //第二行字符地址从 0x40 起始
WriteCmd(m | 0x80);//设置 RAM 地址
/* 在液晶上显示字符串,(x,y)-对应屏幕上的起始坐标,str-字符串指针 */
Lcdaddr(x,y);
while(*str != '\0')
WriteData(*str++);
/* 初始化 1602 液晶 */
void init1602()
WriteCmd(0x38);
WriteCmd(0x0C);
WriteCmd(0x06);
WriteCmd(0x01);
/* 整型数转换为字符串,str-字符串指针,dat-待转换数,返回值-字符串长度 */
unsigned char IntToString(unsigned char *str, int dat)
uchar i = 0;
unsigned char len = 0;
unsigned char buf[6];
if (dat < 0) //如果为负数,首先取绝对值,并在指针上添加负号
dat = -dat;
*str++ = '-';
len++;
do //先转换为低位在前的十进制数组
buf[i++] = dat % 10;
dat /= 10;
} while (dat > 0);
len += i; //i最后的值就是有效字符的个数
while (i-- > 0) //将数组值转换为ASCII码反向拷贝到接收指针上
*str++ = buf[i] + '0';
*str = '\0'; //添加字符串结束符
return len; //返回字符串长度
/*简易延时*/
void delay(uint x)
uchar i,j;
for(i=x;i>0;i--)
for(j=110;j>0;j--);
/*控制键扫描函数,开始结束*/
void Keycontrol()
if(K0==0) //开始键
delay(10);
if(K0==0)
while(!K0);
WriteCmd(0x01);
sec=20;
TR0=~TR0;
e_flag=0;
flag=1;
s_flag = 1;//表示已经开始
if(K5==0)
delay(10);
if(K5==0 && flag==0)
while(!K5);
e_flag =1;//表示结束
Buzz = 0;
Lcdshow(9,0,"Successed");
if(K8==0) //查分键
uchar ch;
delay(10);
if(K8==0 && e_flag==1) //按键按下且此时已结束
while(!K8);
WriteCmd(0x01);
Lcdshow(0,0,"P1:");
ch=(char) (score[1]+48);
WriteData(ch);
Lcdshow(10,0,"P2:");
ch=(char) (score[2]+48);
WriteData(ch);
Lcdshow(0,1,"P3:");
ch=(char) (score[3]+48);
WriteData(ch);
Lcdshow(10,1,"P4:");
ch=(char) (score[4]+48);
WriteData(ch);
/*四路热键扫描(哪个键先按下,哪个优先级最高) */
void KeyScan()
if( K1==0 && flag != 0 && s_flag==1)
delay(10);
if(K1==0)
while(!K1);
num=1; //数码管显示1号"1"
TR0=0; //关闭定时器0,时间停止
TR1=1; //按下抢答器,蜂鸣器提醒
flag=0; //关闭开始键标志位,使再按其他三个键不会响应
if( K2==0 && flag != 0 && s_flag==1) //以下三个按键同一
delay(10);
if(K2==0)
while(!K1);
num=2;
TR0=0;
TR1=1;
flag=0;
if( K3==0 && flag != 0 && s_flag==1)
delay(10);
if(K3==0)
while(!K1);
num=3;
TR0=0;
TR1=1;
flag=0;
if( K4==0 && flag != 0 && s_flag==1)
delay(10);
if(K4==0)
while(!K1);
num=4;
TR0=0;
TR1=1;
flag=0;
void Judge()
if( K6==0 ) //Yes按键
delay(10);
if(K6==0)
while(!K6);
WriteCmd(0x01);
Lcdshow(0, 0, "Your answer is:");
Lcdshow(0, 1, "Right");
score[num]++;//为选手加分
if( K7==0 )
delay(10);
if(K7==0)
while(!K7);
WriteCmd(0x01);
Lcdshow(0, 1, "Worry");
void Time0 () interrupt 1
TH0 = 0xFC;
TL0 = 0x67;//重赋值
cnt++;
if(cnt>=1000)
cnt = 0;
sec--;
if(sec==0)
TR0 = 0;
void Time1 () interrupt 3
TH1=(65536-2000)/256;
TL1=(65536-2000)%256;
Buzz = ~Buzz;
cnt1++;
if(cnt1==1000)
cnt1=0;
TR1=0;
4路抢答器1602显示.zip
(53.54 KB, 下载次数: 47)
2019-12-25 21:44 上传
点击文件名下载附件
下载积分: 黑币 -5
luozhao
2019-12-25 21:47
注释乱码了
