STC15W408AS0-10V电压测量 LCD1602显示
czhaii
2020-1-3 20:48
/****LCD1602 *********电压表测量0-1024PAST*******/
/*************2018 12 28 CODE1844 L283**********/
#include <REG52.H> //按键加减输入数字
#include <intrins.H> //输出0-10电压
sfr P1ASF=0x9D; //P1口第2功能控制寄存器
#define ADC_SPEEDLL 0x00 //540个时钟
#define Lcd_Bus P3
sbit RS=P5^4; //LCD PIN4
sbit RW=P1^7; //LCD PIN5
sbit E=P1^6; //LCD PIN6
sbit OUT1=P1^5;
float ADvalue; //存放AD转换返回的结果
uint val;
uint aa=0; /****RUN FLAG****/
uchar code disdt[10]={0X30,0X31,0X32,0X33,0X34,0X35,0X36,0X37,0X38,0X39};
/*------------------延时子程序------------------------*/
void delay(uint ms)
uint i,j;
for(i=0;i<ms;i++)
for(j=0;j<2000;j++)
void delay_1ms(uint x)
int i, j;
for (i=0; i<x; i++)
for (j=0; j<1500; j++);
void chk_busy()
RS=0;
RW=1;
E=1;
Lcd_Bus=0xff;
while((Lcd_Bus&0x80)==0x80);
E=0;
/*------------------写命令到LCD-----------------------*/
void write_com(uchar cmdcode)
chk_busy();
RS=0;
RW=0;
E=1;
Lcd_Bus=cmdcode;
delay(5); /*在数据写入的时候加入适当的延时*/
E=0;
delay(5);
/*-------------------写数据到LCD----------------------*/
void write_data(uchar Dispdata)
chk_busy();
RS=1;
RW=0;
E=1;
Lcd_Bus=Dispdata;
delay(5); /*在数据写入的时候加入适当的延时 */
E=0;
delay(5);
/*------------------初始化LCD屏-----------------------*/
void lcd_init()
write_com(0X38); /**/
delay_1ms(100);
write_com(0X0E);
delay_1ms(100);
write_com(0X06);
void dis_play1(uint val) /*显示A函数*/
uint Data_a,Data_b,Data_c,Data_d;
Data_a=val/1000;
Data_b=(val-Data_a*1000)/100;
Data_c=(val-Data_a*1000-Data_b*100)/10;
Data_d=val-Data_a*1000-Data_b*100-Data_c*10;
write_com(0X80); /*地址*/
write_data(0X50); /*P*/
write_com(0X81); /*地址*/
write_data(0X31); /*1*/
write_com(0X82); /*地址*/
write_data(0X3A); /*1*/
write_com(0X83); /*地址*/
write_data(disdt[Data_b]); /*十位*/
write_com(0X84); /*地址*/
write_data(disdt[Data_c]); /*个位*/
write_com(0X85); /*地址*/
write_data(0X2E); /*.*/
write_com(0X86); /*地址*/
write_data(disdt[Data_d]); /*个位*/
write_com(0X87); /*地址*/
write_data(0X56); /*V*/
void dis_play2(uint val) /*显示A函数*/
Data_a=val/1000;
write_com(0X88); /*地址*/
write_data(0X53); /*S*/
write_com(0X89); /*地址*/
write_com(0X8A); /*地址*/
write_com(0X8B); /*地址*/
write_com(0X8C); /*地址*/
write_com(0X8D); /*地址*/
write_com(0X8E); /*地址*/
write_com(0X8F); /*地址*/
void dis_play3(uint val) /*显示A函数*/
Data_a=val/1000;
write_com(0XC0); /*地址*/
write_com(0XC1); /*地址*/
write_data(0X32); /*2*/
write_com(0XC2); /*地址*/
write_com(0XC3); /*地址*/
write_com(0XC4); /*地址*/
write_com(0XC5); /*地址*/
write_com(0XC6); /*地址*/
write_com(0XC7); /*地址*/
void dis_play4(uint val) /*显示A函数*/
Data_a=val/1000;
write_com(0XC8); /*地址*/
write_com(0XC9); /*地址*/
write_com(0XCA); /*地址*/
write_com(0XCB); /*地址*/
write_com(0XCC); /*地址*/
write_com(0XCD); /*地址*/
write_com(0XCE); /*地址*/
write_com(0XCF); /*地址*/
unsigned int ADC_P10() //
uint i;
uchar status=0; //AD转换结束标志
uint AD_Dat=0; //10位AD转换值
ADC_CONTR|=0X80; //打开ADC转换电源,第一次使用时要打开内部电源
for(i=0;i<10000;i++) //等待电源稳定1ms
P1ASF|=0X00; //0000 0000
ADC_CONTR=0XE0; //1110 0000 通道P1.0
for(i=0;i<1000;i++) //如果多通道测量,更换通道后延时200us
ADC_CONTR|=0X08; //启动AD转换 0000 1000ADC_START
while(status==0) //等待AD转换结束
status=ADC_CONTR&0X10; //判断ADC_FLAG是否等于1,
ADC_CONTR&=0XE7; //将ADC_FLAG清零
AD_Dat=(ADC_RES<<2)|(ADC_RESL&0X03); //
return AD_Dat; //
unsigned int ADC_P11() //
uint i;
P1ASF|=0X02; //0000 0010
ADC_CONTR=0XE1; //1110 0001
return AD_Dat; //
unsigned int ADC_P13() //
uint i;
P1ASF|=0X08; //0000 1000
ADC_CONTR=0XE3; //1110 0011 P1.3
return AD_Dat; //
unsigned int ADC_P14() //
uint i;
P1ASF|=0X10; //0001 0000
ADC_CONTR=0XE4; //1110 0100
return AD_Dat; //
/*------------------主循环程序----------------*/
void main( ) /*主程序开始*/
P1M0=0X00;
P1M1=0X1B;
P5M0=0X00;
P5M1=0X00;
OUT1=0;
delay(500);
OUT1=1;
lcd_init() ; /*液晶复位*/
OUT1=~OUT1;
ADvalue=ADC_P11()/9; //采样P1.1口模拟输入电压 9根据输入电压,芯片电压测试得出
dis_play1(ADvalue);
delay(10); //1023/12 V输入
ADvalue=ADC_P10()/9; //采样P1.1口模拟输入电压 9根据输入电压,芯片电压测试得出
dis_play2(ADvalue);
delay(10);
ADvalue=ADC_P13()/9; //采样P1.1口模拟输入电压 9根据输入电压,芯片电压测试得出
dis_play3(ADvalue);
delay(10);
ADvalue=ADC_P14()/9; //采样P1.1口模拟输入电压 9根据输入电压,芯片电压测试得出
dis_play4(ADvalue);
delay(10);
} //主循环
版权声明:本文为CSDN博主「czhaii」的原创文章,遵循 CC 4.0 BY-SA 版权协议,转载请附上原文出处链接及本声明。
原文链接:
https://blog.csdn.net/czhaii/article/details/89790529
oohoh
2020-1-4 14:03
请问基准电压怎么设置
czhaii
2020-1-7 10:20
看STC官方手册
