arduino的hmc5883L源程序
2572727
2020-1-7 16:18
arduino的hmc5883L源程序
有关arduino的hmc5883L磁力计的开发程序
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include <Wire.h>
#include "HMC5883L.h"
bool HMC5883L::begin()
Wire.begin();
if ((fastRegister8(HMC5883L_REG_IDENT_A) != 0x48)
|| (fastRegister8(HMC5883L_REG_IDENT_B) != 0x34)
|| (fastRegister8(HMC5883L_REG_IDENT_C) != 0x33))
return false;
setRange(HMC5883L_RANGE_1_3GA);
setMeasurementMode(HMC5883L_CONTINOUS);
setDataRate(HMC5883L_DATARATE_15HZ);
setSamples(HMC5883L_SAMPLES_1);
mgPerDigit = 0.92f;
return true;
Vector HMC5883L::readRaw(void)
v.XAxis = readRegister16(HMC5883L_REG_OUT_X_M) - xOffset;
v.YAxis = readRegister16(HMC5883L_REG_OUT_Y_M) - yOffset;
v.ZAxis = readRegister16(HMC5883L_REG_OUT_Z_M);
return v;
Vector HMC5883L::readNormalize(void)
v.XAxis = ((float)readRegister16(HMC5883L_REG_OUT_X_M) - xOffset) * mgPerDigit;
v.YAxis = ((float)readRegister16(HMC5883L_REG_OUT_Y_M) - yOffset) * mgPerDigit;
v.ZAxis = (float)readRegister16(HMC5883L_REG_OUT_Z_M) * mgPerDigit;
return v;
void HMC5883L::setOffset(int xo, int yo)
xOffset = xo;
yOffset = yo;
void HMC5883L::setRange(hmc5883l_range_t range)
switch(range)
case HMC5883L_RANGE_0_88GA:
mgPerDigit = 0.073f;
break;
case HMC5883L_RANGE_1_3GA:
mgPerDigit = 0.92f;
break;
case HMC5883L_RANGE_1_9GA:
mgPerDigit = 1.22f;
break;
case HMC5883L_RANGE_2_5GA:
mgPerDigit = 1.52f;
break;
case HMC5883L_RANGE_4GA:
mgPerDigit = 2.27f;
break;
case HMC5883L_RANGE_4_7GA:
mgPerDigit = 2.56f;
break;
case HMC5883L_RANGE_5_6GA:
mgPerDigit = 3.03f;
break;
case HMC5883L_RANGE_8_1GA:
mgPerDigit = 4.35f;
break;
default:
break;
writeRegister8(HMC5883L_REG_CONFIG_B, range << 5);
hmc5883l_range_t HMC5883L::getRange(void)
return (hmc5883l_range_t)((readRegister8(HMC5883L_REG_CONFIG_B) >> 5));
void HMC5883L::setMeasurementMode(hmc5883l_mode_t mode)
uint8_t value;
value = readRegister8(HMC5883L_REG_MODE);
value &= 0b11111100;
value |= mode;
writeRegister8(HMC5883L_REG_MODE, value);
hmc5883l_mode_t HMC5883L::getMeasurementMode(void)
uint8_t value;
value &= 0b00000011;
return (hmc5883l_mode_t)value;
void HMC5883L::setDataRate(hmc5883l_dataRate_t dataRate)
uint8_t value;
value = readRegister8(HMC5883L_REG_CONFIG_A);
value &= 0b11100011;
value |= (dataRate << 2);
writeRegister8(HMC5883L_REG_CONFIG_A, value);
hmc5883l_dataRate_t HMC5883L::getDataRate(void)
uint8_t value;
value &= 0b00011100;
value >>= 2;
return (hmc5883l_dataRate_t)value;
void HMC5883L::setSamples(hmc5883l_samples_t samples)
uint8_t value;
value &= 0b10011111;
value |= (samples << 5);
hmc5883l_samples_t HMC5883L::getSamples(void)
uint8_t value;
value &= 0b01100000;
value >>= 5;
return (hmc5883l_samples_t)value;
// Write byte to register
void HMC5883L::writeRegister8(uint8_t reg, uint8_t value)
Wire.beginTransmission(HMC5883L_ADDRESS);
#if ARDUINO >= 100
Wire.write(reg);
Wire.write(value);
#else
Wire.send(reg);
Wire.send(value);
#endif
Wire.endTransmission();
// Read byte to register
uint8_t HMC5883L::fastRegister8(uint8_t reg)
uint8_t value;
#if ARDUINO >= 100
Wire.write(reg);
#else
Wire.send(reg);
#endif
Wire.requestFrom(HMC5883L_ADDRESS, 1);
#if ARDUINO >= 100
value = Wire.read();
#else
value = Wire.receive();
#endif;
return value;
// Read byte from register
uint8_t HMC5883L::readRegister8(uint8_t reg)
uint8_t value;
#if ARDUINO >= 100
Wire.write(reg);
#else
Wire.send(reg);
#endif
while(!Wire.available()) {};
#if ARDUINO >= 100
#else
#endif;
return value;
// Read word from register
int16_t HMC5883L::readRegister16(uint8_t reg)
int16_t value;
#if ARDUINO >= 100
Wire.write(reg);
#else
Wire.send(reg);
#endif
Wire.requestFrom(HMC5883L_ADDRESS, 2);
#if ARDUINO >= 100
uint8_t vha = Wire.read();
uint8_t vla = Wire.read();
#else
uint8_t vha = Wire.receive();
uint8_t vla = Wire.receive();
#endif;
value = vha << 8 | vla;
return value;
Arduino-HMC5883L-master.zip
(540.79 KB, 下载次数: 13)
2020-1-7 16:18 上传
点击文件名下载附件
下载积分: 黑币 -5
