标题: LCD1602显示数值程序 [打印本页]
作者: 梦醒了11    时间: 2020-3-19 16:20
标题: LCD1602显示数值程序
#include<reg52.h>
uchar code table[]={"I Like YOU!"};  //多字符用双引号
uchar code table1[]={"I lOVE YOU!"};
sbit lcden=P0^5;
sbit lcdrs=P0^7;
sbit lcdrw = P0^6;
uchar num;
void delay(uint z)                                //延时函数
uint x,y;
        for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void write_com(uchar com)
        lcdrs=0;      //写指令
        lcdrw=0;
        P2=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar date)         //写数据
        lcdrs=1;
        lcdrw=0;
        P2=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
                lcden=0;
                write_com(0x38);                                    //显示指令
                write_com(0x0f);                                //(0f:闪烁 0e:不闪烁)
                write_com(0x06);
                write_com(0x01);                                  //清屏
          init();
                  write_com(0x80);                           //地址初始化
          for(num=0;num<11;num++)
          write_data(table[num]);
          delay(20);                        }
           write_com(0x80+0x40+3);                //换行 在缩进3
          write_data(table1[num]);
          delay(20);
          while(1);
