标题: 求解答:关于蓝牙控制进入单片机串口中断的问题 [打印本页]
作者: 嘿嘿哈哈哦耶    时间: 2020-3-21 18:24
求大神解答:小辈不知道为什么这个程序蓝牙无法触发中断(如果不出意外 这个程序的显示为蓝牙触发舵机转动 并在oled上显示舵机转动状态)
#include "REG51.h"
#include "led.h"
#include "spi.h"
#include "bmp.h"
sbit SG_PWM=P2^0;
unsigned char count=0;
unsigned char PWM_count=1;
unsigned char  order;
void Timer_Init()
  TMOD=0X01;
  TH0=0Xfe;
  TL0=0X0c;       //????????????0.5ms   ?0.5ms????????ж?
  ET0=1;
  TR0=1;
  EA=1;
void Timer() interrupt 1
  TR0=0;
  TH0=0Xfe;
  TL0=0X0c;
  if(count<=PWM_count)
    SG_PWM=1;
    SG_PWM=0;
  count++;
  if(count>=40)
    count=0;
  TR0=1;
void InitUART(void)
    TMOD = 0x20;
    SCON = 0x50;
    TH1 = 0xF3;
    TL1 = TH1;
    PCON = 0x80;
    EA = 1;
    ES = 1;
    TR1 = 1;
void UARTInterrupt(void) interrupt 4
     LED_Toggle();
     order=SBUF;
  Timer_Init();
switch(order)
case '0':
     LED_Toggle();
    PWM_count=1;
            count=0;
            EA=1;
           OLED_Clear();
        OLED_Display_GB2312_string(1,0,"顺时针45度");break;
case '1':
LED_Toggle();
   PWM_count=0;
             count=0;
            EA=1;
    OLED_Clear();
  OLED_Display_GB2312_string(1,0,"顺时针180度"); break;
case '2':
LED_Toggle();
       PWM_count=3;
             count=0;
              EA=1;
      OLED_Clear();
      OLED_Display_GB2312_string(1,0,"顺时针减90度");break;
case '3':
LED_Toggle();
             PWM_count=1;
             count=0;
              EA=1;
               OLED_Clear();
             OLED_Display_GB2312_string(1,0,"顺时针加90度");break;
              default:break;
  RI=0;
     SBUF=order;
  while(!TI)
    TI=0;
void main(void)
   float t=0;
    Timer_Init();
     InitUART();
OLED_Init();
OLED_ColorTurn(0)
    OLED_DisplayTurn(0)
OLED_Clear();
