标题: 单片机定时器0的方式1实现一个发光二极管以500ms间隔闪烁,用定时器1的方式1实现两... [打印本页]
作者: yqx4327023    时间: 2020-3-27 17:02
定时器0的方式1实现一个发光二极管以500ms间隔闪烁,用定时器1的方式1实现两位数码...
#include <reg51.h>
sbit LED=P1^0;                 //连的是LED
#define MAX_NUM     99         //最大倒计时数
#define SEGPORT     P0         //定义数码管连接端口
sbit LE_DUAN = P2^6;           //定义573锁存使能端口 段锁存
sbit LE_WEI  = P2^7;           //定义573锁存使能端口 位锁存
unsigned char code Seg_Duan[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};   //共阴数码管显示段码值 0~9
unsigned char code Seg_Wei[]  = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};             //数码管的位码,低电平有效。
static uchar second=MAX_NUM,count0,count1;
uchar shiwei;
uchar gewei;
void delay(unsigned int cnt)
while(--cnt);
  TMOD=0x11;
  TH0=(65536-50000)/256;                                //定时时间   50ms
  TL0=(65536-50000)%256;
  TH1=(65536-50000)/256;
  TL1=(65536-50000)%256;
  EA=1;
  ET0=1;
  TR0=1;
  ET1=1;
  TR1=1;
  SEGPORT = 0;
  LE_DUAN = 0;
  LE_WEI  = 0;
   shiwei=second/10;                       //数码管十位
   gewei=second%10;                        //数码管个位
   SEGPORT=0;                              //清空数据
   LE_DUAN=1;                              //段锁存
   LE_DUAN=0;
   delay(30);
   SEGPORT = Seg_Wei[1];                   //先送位码值
   LE_WEI = 1;                             //573高电平锁存
   LE_WEI = 0;
   SEGPORT = Seg_Duan[shiwei];             //再送段码值
   LE_DUAN = 1;                            //573高电平锁存
   LE_DUAN = 0;
   delay(300);
   SEGPORT = Seg_Wei[0];                   //先送位码值
   LE_WEI = 0;
   SEGPORT = Seg_Duan[gewei];              //再送段码值
   LE_DUAN = 0;
   delay(300);
void tim0(void) interrupt 1    //定时器0中断
  count0++;
  if(count0==10)               //50毫秒定时,50*10=500(毫秒)
   count0=0;
   LED=~LED;                  //LED取反
void tim1(void) interrupt 3    //定时器1中断
  count1++;
  if(count1==20)              //50毫秒定时,50*20=1000(毫秒)=1(秒)
   count1=0;
   second--;
   if(second==0xff)
   second=MAX_NUM;
作业.rar
31.81 KB, 下载次数: 6, 下载积分: 黑币 -5
