关于ADXL345传感器程序的问题
luoxingyang000
2020-4-4 16:35
关于ADXL345传感器程序的问题
在STC89C52RC 上,XYZ都没有数据,我用的LCD1602屏是 IIC的,会不会起冲突啊。。。
#include<reg52.h>
#include<PCF8574.h>
#include<stdio.h>
#include "math.h"
#include "adxl345.h"
unsigned char jl[]="jl00M";
unsigned char bs[]= "bs00";
unsigned char ReadAdxl345;
char dis0[16];
xdata char dis1[16];
xdata char dis2[16];
unsigned long time_20ms=0;
unsigned char ReportFlag=0;
unsigned int BuShu=0;
float JuLi=0;
float KaLuLi=0;
unsigned char statFlag = 0;
void Init_Timer0(void);
void SendStr(unsigned char *s,unsigned char length);
void UART_Init(void);
void SendByte(unsigned char dat);
void BuShuCheck(void);
void delay1(uchar x)
uchar a,b;
for(a=x;a>0;a--)
for(b=200;b>0;b--);
void delayms(unsigned int xms)
unsigned int x,y;
for(x=xms;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
{ uchar com1,com2;
com1=com|0x0f;
write_add(com1&0xfc);
delay1(2);
write_add(com1&0xf8);
com2=com<<4;
com2=com2|0x0f;
write_add(com2&0xfc);
delay1(2);
write_add(com2&0xf8);
void write_date(uchar date)
uchar date1,date2;
date1=date|0x0f;
write_add(date1&0xfd);
delay1(2);
write_add(date1&0xf9);
date2=date<<4;
date2=date2|0x0f;
write_add(date2&0xfd);
delay1(2);
write_add(date2&0xf9);
void init_lcd()
write_com(0x33);
delayms(6);
write_com(0x32);
delayms(6);
write_com(0x28);
delayms(6);
write_com(0x01);
delayms(6);
write_com(0x06);
delayms(6);
write_com(0x0c);
//write_LCD_Command(0x0f);
delayms(6);
void ShowString(unsigned char x,unsigned char y,unsigned char *str)
if(x == 1)
write_com(0x80 | y-1);
if(x == 2)
write_com(0xc0 | y-1);
while(*str!='\0')
write_date(*str);
str++;
void main(void)
{ Init_Timer0();
UART_Init();
if(Single_Read_ADXL345(0X00)==0xe5)
delayms(5);
delayms(3);
BuShuCheck();
bs[2]='0'+BuShu/10;
bs[3]='0'+BuShu%10;
jl[2]='0'+(BuShu/2)/10;
jl[3]='0'+(BuShu/2)%10;
init_lcd();
ShowString(2,12,jl);
ShowString(1,13,bs);
delayms(10000);
static unsigned char ErrorNum=0;
static unsigned char NormalNum=0;
static unsigned char CheckNum=0;
static unsigned char shuNum=0;
static unsigned char ceNum=0;
static unsigned int remBuShu=0;
ReadAdxl345=0;
ReadData_x();
CheckNum++;
if((temp_X<650)||(abs(temp_Y)>400))
ErrorNum++;
shuNum++;
{NormalNum++; ceNum++;}
if((NormalNum!=0)&&(ErrorNum!=0))
ErrorNum=0;
NormalNum=0;
BuShu++;
JuLi=(float)(BuShu/2)*0.45;
KaLuLi=JuLi*70*0.832;
if(CheckNum>=20)
if((ceNum!=0)&&(shuNum==0))
statFlag = 0;
else if((ceNum==0)&&(shuNum!=0))
statFlag = 1;
else if((ceNum!=0)&&(shuNum!=0))
if((BuShu - remBuShu)>=6)
{statFlag = 2;}
{statFlag = 3;}
remBuShu = BuShu;
CheckNum=0;
ceNum=0;
shuNum=0;
TMOD |= 0x01;
TH0=(65536-20000)/256;
TL0=(65536-20000)%256;
EA=1;
ET0=1;
TR0=1;
void Timer0_isr(void) interrupt 1
time_20ms++;
if(time_20ms%5==0)
ReadAdxl345=1;
if(time_20ms%50==0)
ReportFlag=1;
SCON = 0x50;
TMOD |= 0x20;
TH1 = 0xFD;
TL1 = TH1;
TR1 = 1;
EA = 1;
ES = 1;
void DelayUs2x(unsigned char t)
while(--t);
unsigned char time_out;
time_out=0x00;
SBUF = dat;
while((!TI)&&(time_out<100))
{time_out++;DelayUs2x(10);}
TI = 0;
unsigned char NUM;
NUM=0x00;
while(NUM<length)
SendByte(*s);
s++;
NUM++;
void UART_SER (void) interrupt 4
if(RI)
RI=0;
if(TI)
TI=0;
luoxingyang000
2020-4-4 16:35
temp_X、temp_Y,temp_Z 都没有显示
