标题: 程序为什么达到指定的温度和感应到有人后,显示屏就会定住不刷新了,而且也发不出信息 [打印本页]
作者: 吾问无为谓无无    时间: 2020-4-18 22:08
    static uchar value;
        Uart_Init();
        chushihua_kz();          //初始化SIM800C模块
        init_1602();                    //1602初始化
        time_init();                    //初始化定时器
//        init_int0();
         if(flag_200ms == 1)                //300ms 处理一次温度程序
                        flag_200ms = 0;
                        value ++;
                        if(value >= 4)
                                value = 0;
                                if(miao != 0)
                                        miao --;    //时间减1
                                if(miao == 0)
                                        flag_en = 0;
                        if(hw == 1)  //感应到人
                                miao = 30;
                                write_string(1,14,"Y ");
                                flag_en = 1;
                                write_string(1,14,"N ");
                                write_sfm2(1,0,miao);
                        temperature = read_temp();        //先读出温度的值
                        fengshan_kz();        //风扇控制函数
                        write_sfm3_18B20(1,8,temperature);
                        if((flag_en == 1)&&(temperature >= t_high))
                         sendMessage(phoneNumber,msg);      //发送信息
