数码管显示矩阵键盘数字 单片机程序
01156165465
2020-4-19 14:51
数码管显示矩阵键盘数字 单片机程序
(67.36 KB, 下载次数: 32)
下载附件
2020-4-19 14:50 上传
#include<reg52.h> //????????????P0?ο??P1λ??//
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
sbit k1=P3^4;
sbit k2=P3^5;
sbit k3=P3^6;
sbit k4=P3^7;
void delayms(uint);
void display(uchar);
void mkcan();
uchar num;
P0=0x00;
P1=0x00;
mkcan();
void delayms(uint xms) //???//
uint i,j;
for(i=xms;i>0;i--)
for(j=100;j>0;j--);
void mkcan()
uchar temp,k;
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delayms(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xee:
k=0;
break;
case 0xde:
k=1;
break;
case 0xbe:
k=2;
break;
case 0x7e:
k=3;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(k);
P3=0xfd;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delayms(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xed:
k=4;
break;
case 0xdd:
k=5;
break;
case 0xbd:
k=6;
break;
case 0x7d:
k=7;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(k);
P3=0xfb;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delayms(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xeb:
k=8;
break;
case 0xdb:
k=9;
break;
case 0xbb:
k=10;
break;
case 0x7b:
k=11;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(k);
P3=0xf7;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delayms(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xe7:
k=12;
break;
case 0xd7:
k=13;
break;
case 0xb7:
k=14;
break;
case 0x77:
k=15;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(k);
void display(uchar num)
P0=table[num];
