51单片机+8155芯片的交通灯程序
元亨利贞
2020-5-6 21:36
51单片机+8155芯片的交通灯程序
最近做了一个关最近做了一个关于8155模拟交通灯的运行系统,写的不好,还有很多不足,有的地方还不完善,请大家多多指教。
电路原理图如下:
(146.25 KB, 下载次数: 49)
下载附件
2020-5-6 21:30 上传
#include<reg52.h>
# include <absacc.h>
#define uchar unsigned char //定义为uchar类型
#define uint unsigned int //定义为uint类型
# define COM XBYTE[0XFE00] //控制字地址(总控制,决定了PA/B/C是写还是读等)
# define PA XBYTE[0XFE01] //控制PA地址(总控制写的是读时,里面存的是读的值;
// 写的是写时,里面要写入控制值)
# define PB XBYTE[0XFE02] //控制PB地址
# define PC XBYTE[0XFE03] //控制PC地址
sbit g = P2^1;
sbit s = P2^2;
sbit eg = P2^3;
sbit ws = P2^4;
//sbit Key_N = P1^4; //独立按键
//sbit Key_S = P1^5;
//sbit Key_W = P1^6;
//sbit Key_E = P1^7;
sbit KEYA = P1^4;
sbit KEYB = P1^5;
uint ge,shi; //定义全局变量
uint m = 30;
uint n;
uint num;
/*交通灯的数值*/
uchar lcd1 = 10; //倒计时初始值为25用于改变
uchar lcd2 = 15; //的倒计时初始值为30用于改变
uchar lcd11; //倒计时
uchar lcd22; //倒计时
uchar change1; //LCD1红绿灯转换
uchar yellow1 = 3;
/*一些辅助标志位的声明*/
uchar code smguan[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; //数码管显示0~9
uchar t=3;
uchar sign = 0;
uchar time_Count; //进行计时
void delay(uint t)
while(t--);
void Digital(uint ge,uint shi) //数码管显示
PA = smguan[ge];
s = 1;
delay(500);
s = 0;
PA = smguan[shi];
g = 1;
delay(500);
g = 0;
PB = smguan[ge];
eg = 1;
delay(500);
eg = 0;
PB = smguan[shi];
ws = 1;
delay(500);
ws = 0;
void Traffic_lights()
if(t == 3)
P1 = 0x01;
if(m == 0)
m = 3;
t = 2;
if(t == 2)
P1 = 0x02;
if(m == 0)
m = 30;
t = 1;
if(t == 1)
P1 = 0x04;
if(m == 0)
m = 3;
t = 0;
if(t == 0)
P1 = 0x02;
if(m == 0)
m = 30;
t = 3;
void INIT()
IT0=1;
IT1=1;
EX0=1;
EX1=1;
EA=1;
Avenger
2020-5-10 08:31
可否附上仿真研究一番
1718645907
2020-6-6 19:47
能否把仿真源程序下载
hantu
2020-9-11 09:37
主函数main()都不写还拿来分享干嘛
