标题: Proteus8.9 VSM Studio Keil编译器仿真AT89C51RD2系列016_lcd12064bit [打印本页]
作者: kaillen    时间: 2020-5-19 23:13
一,打开文件(可以随文下载放置在文档中打开)。(如下图1所示)
图1
二,调整原理图大小,适合可视,另存工程文件。(如下图2,3,4所示)
图2
图3
图4
三,点击Source Code标签。(如下图5所示)
图5
四,编辑main.c 代码如Proteus8.9 VSM Studio Keil编译器仿真AT89C51RD2系列016_lcd12064bit (如下图6所示)
图6
五,Main.c 代码:
/* Main.c file generated by New Project wizard
*Coder:       Ziegler Yin
* Created:   周日 5月 3 2020
* Processor: AT89C51RD2
* Compiler:  Keil for 8051
#include "lcd16024bit.h"
int lcd_putstr(u8 *ddat, int pos)
        u8 i;
        if(pos== -1) {
                write_com(0x01);
                delay(2); pos= 0;
        while((*ddat)!= '\0') {
                switch(*ddat) {
                        case '\n':
                                if(pos< 17) {
                                        for(i= pos; i< 16; i++) lcd_wrtchr(pos% 16, pos/ 16, ' ');
                                        pos=16;
                                else {
                                        for(i= pos; i< 32; i++) lcd_wrtchr(pos% 16, pos/ 16, ' ');
                                        pos=0;
                                break;
                        case '\b':
                                if(pos>0) pos--;
                                        break;
                        default:
                                if((*ddat) < 0x20) {
                                        *ddat= ' ';
                                lcd_wrtchr(pos% 16, pos/ 16, *ddat);
                                pos++;
                                break;
                *ddat++;
        return (pos);
int lcd_putnum(u32 num, int XS, int pos)
        u32 tmp= 0;
        u8 numbits= 0;
        if(pos== -1) {
                write_com(01);
                delay(2); pos= 0;
        if(num== 0) {
                lcd_wrtchr(pos% 16, pos/16, '0');
                pos++;
        else {
                if(num< 0) {
                        lcd_wrtchr(pos% 16, pos/16, '-');
                        num*= (-1);
                        pos++;
                while(num) {
                        tmp= tmp* 10+  (num% 10);
                        num= num/ 10;
                        numbits++;
                while(tmp) {
                        lcd_wrtchr(pos% 16, pos/16, (tmp% 10) +48);
                        tmp /=10;
                        pos++;
                        numbits--;
                        if(numbits== XS) pos= lcd_putstr(".", pos);
                while(numbits--) {
                        pos--;
        return (pos);
void main(void)
       init();
        while(1){
                LClear();
                delay(500);
                lcdStr(0, 0, "Kaillen Work");
                lcdStr(0, 1, "  Wellcom YOU!");
                delay(5000);
                LClear();
                delay(500);
                lcdStr(0, 0, "Code Made");
                lcdStr(0, 1, " --Ziegler Yin");
                delay(5000);
Lcd16024bit.h:
*Coder:       Ziegler Yin
#ifndef __LCD16024BIT_H_
#define __LCD16024BIT_H_
#include <reg51.h>
#include <stdio.h>
#include "INTRINS.H"
#define u32 unsigned long
#define u16 unsigned int
#define u8 unsigned char
sbit lcdrs =P2^7;  //液晶屏数据/命令选择端
sbit lcdrw =P2^6;        //液晶屏读写端
sbit lcden =P2^5;        //使能端
void delay(int z);
void write_com(u8 com);
void write_data(u8 date );
void SetCursor(u8 ix, u8 iy);
void lcd_wrtchr(u8 X, u8 Y, u8 recd);
void lcdStr(u8 x, u8 y, u8 *str);
void init(void);
void LClear(void);
#endif
六,点击构建工程按钮,编译工程。(如下图7所示)
图7
七,点击窗口左下方仿真按钮,可见lcd16024bit屏上信息显示在屏。 (如下图8,9,10所示)
图8
图9
图10
八,选择release,点击构建工程按钮,编译工程生成Hex文件。(如下图11所示)
图11
九, 系列的001-003虚拟仿真与开发板对应已证明:虚拟仿真程序对于开发板有效,之后不再➕上下载到开发板的介绍。
附件Proteus8.9 VSM Studio Keil编译器仿真AT89C51RD2系列016_lcd12064bit在已安装Proteus8.9的计算机文件夹中打开即可
需要进一步了解,请加入QQ群:976235464
Keil_AT89C51RD2_016_lcd1602_4bit_03.rar
130.66 KB, 下载次数: 8, 下载积分: 黑币 -5
