标题: quartues编写的计数器 modelsim仿真没有输出 [打印本页]
作者: 2107972907    时间: 2020-5-22 15:29
quartues编写的一个计数器,,modelsim仿真时的输出波形是直线。。付给初值后一直输出初值,clk显示正常
激励文件
library ieee;
use ieee.std_logic_1164.all;
entity clock_tb is
end entity clock_tb;
architecture behaviour of clock_tb is
        component clock
                port(
                                clk: in std_logic;
                                clr: in std_logic;
                                seg: out std_logic_vector(7 downto 0);
                                dig: buffer std_logic_vector(2 downto 0)
        end component;
        signal clk:std_logic;
        signal clr:std_logic;
        signal seg:std_logic_vector(7 downto 0):="01000000";
        signal dig:std_logic_vector(2 downto 0):="000";
begin
        u1: clock
                port map(
                        clk=>clk,
                        clr=>clr,
                        seg=>seg,
                        dig=>dig);
        process begin
                wait for 10 ns;  clk<='1';
                wait for 10 ns;  clk<='0';
        end process;
        process begin
                wait for 0 ns;
                clr <= '0';        --复位开始
                wait for 200.1 ns;
                clr <= '1';        --复位完成
                wait;                        --持续等待
        end process;
end architecture behaviour;
