标题: 利用GY-61 ADXL335模块与51单片机结合测量角度源程序 [打印本页]
作者: weishanghao    时间: 2020-6-5 12:25
利用GY-61 ADXL335模块与51单片机结合测量角度,相关·代码和ADXL335资料全都在压缩包里
//名称:单片机串口输出ADXL335角度值
//使用单片机:stc12c5a60s2
//供电:电压5v
//晶振:11.0592m
//X轴->(ADC0)P1.0
//Y轴->(ADC1)P1.1
//Z轴->(ADC1)P1.2
//用pc串口助手显示时,选择字符显示
//参考宏晶网址例程
#include "reg51.h"
#include "intrins.h"
#include  <math.h>    //Keil library
#include  <stdio.h>   //Keil library
//#define FOSC    18432000L
#define FOSC    11059200L  //晶振11.0592M
#define BAUD    9600
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define   uchar unsigned char
#define   uint unsigned int
/*Declare SFR associated with the ADC */
sfr AUXR1       =   0XA2;
sfr ADC_CONTR   =   0xBC;           //ADC control register
sfr ADC_RES     =   0xBD;           //ADC high 8-bit result register
sfr ADC_RESL    =   0xBE;
sfr ADC_LOW2    =   0xBE;           //ADC low 2-bit result register
sfr P1ASF       =   0x9D;           //P1 secondary function control register
/*Define ADC operation const for ADC_CONTR*/
#define ADC_POWER   0x80            //ADC power control bit
#define ADC_FLAG    0x10            //ADC complete flag
#define ADC_START   0x08            //ADC start control bit
#define ADC_SPEEDLL 0x00            //420 clocks
#define ADC_SPEEDL  0x20            //280 clocks
#define ADC_SPEEDH  0x40            //140 clocks
#define ADC_SPEEDHH 0x60            //70 clocks
void InitUart();
void InitADC();
void SendData(BYTE dat);
int GetADCResult(BYTE ch);
void Delay(WORD n);
uchar ge,shi,bai,qian,wan;           //显示变量
void conversion(uint temp_data)
    wan=temp_data/10000+0x30 ;
    temp_data=temp_data%10000;   //取余运算
        qian=temp_data/1000+0x30 ;
    temp_data=temp_data%1000;    //取余运算
    bai=temp_data/100+0x30   ;
    temp_data=temp_data%100;     //取余运算
    shi=temp_data/10+0x30    ;
    temp_data=temp_data%10;      //取余运算
    ge=temp_data+0x30;
Get ADC result
{   int AD10bitResult;
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
    _nop_();                        //Must wait before inquiry
    _nop_();
    _nop_();
    _nop_();
    while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag
    ADC_CONTR &= ~ADC_FLAG;         //Close ADC
    AD10bitResult=ADC_RES;
    AD10bitResult<<=8;
    AD10bitResult|=ADC_RESL;
    return AD10bitResult;                  //Return 10BIT ADC result
Initial UART
void InitUart()
    SCON = 0x5a;                    //8 bit data ,no parity bit
    TMOD = 0x20;                    //T1 as 8-bit auto reload
    TH1 = TL1 = -(FOSC/12/32/BAUD); //Set Uart baudrate
    TR1 = 1;                        //T1 start running
Initial ADC sfr
void InitADC()
    P1ASF = 0xff;                   //Open 8 channels ADC function
        AUXR1=AUXR1|0X04;              //ad值左对齐
    ADC_RES = 0;                    //Clear previous result
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL;
    Delay(2);                       //ADC power-on and delay
Send one byte data to PC
Input: dat (UART data)
Output:-
    while (!TI);                    //Wait for the previous data is sent
    TI = 0;                         //Clear TI flag
    SBUF = dat;                     //Send current data
Software delay function
void Delay(WORD n)
    WORD x;
    while (n--)
        x = 5000;
        while (x--);
{   int x,y,z;
        float Q,T,K,Roll,Pitch;
    InitUart();                     //Init UART, use to show ADC result
    InitADC();                      //Init ADC sfr
    while (1)
                x=GetADCResult(0);
                y=GetADCResult(1);
                z=GetADCResult(2);
                // 0-5v 对应 0-1024
                // 3.3v/2  = 1.65v(0g时候值)
                // 1.65v ->= 338   (AD值即0X0152)
                x-=0X0152; //
                y-=0X0152;
                z-=0X0152;
    Q=x;
    T=y;
    K=z;
    Q=-Q;
    Roll=(float)(((atan2(K,Q)*180)/3.14159265)+180);
    Pitch=(float)(((atan2(K,T)*180)/3.14159265)+180);
    conversion(Roll);    //横滚角0-360度
  //conversion(Pitch); //俯仰角0-360度
    SendData(bai);
        SendData(shi);
        SendData(ge);
        SendData(0x0d);
        SendData(0x0a);//换行,回车
    Delay(30);
51黑论坛_GY-61 ADXL335模块发送资料.rar
672.39 KB, 下载次数: 22, 下载积分: 黑币 -5
