求大佬帮看看为什么LCD1602不显示?
mars`
2020-6-19 15:52
#include<reg52.h>
#include<intrins.h>
static unsigned char table[6]={0,0,0,0,0,0};
//Declare functions
uchar Busy_Check();
void Initialize_LCD();
void Weite_LCD_Date(uchar dat);
void Write_LCD_Command(uchar cmd);
void Display_String(uchar x,uchar y,uchar *str);
void Display_char(uchar hang,uchar lie,char sign);
void write_add(uchar address,uchar date);//向AT24C中的指定地址写入数据
uchar read_add(uchar address);//从AT24Cxx中的指定地址读取数据
void init();
uchar h=20;
sbit touch=P2^1;
sbit touch1=P2^2;
sbit speaker=P2^0;
void delay(unsigned char ms) //延时**ms
unsigned char i;
while(ms--)
for(i=250;i>0;i--)
_nop_();
_nop_();
_nop_();
_nop_();
unsigned char keyscan() //扫描键盘
unsigned char temp,y,j;
unsigned char anjian[]={0xfe,0xfd,0xfb,0xf7};
for(y=0;y<4;y++)
P1=anjian[y];
temp=0x10;
for(j=0;j<4;j++)
if(!(P1&temp))
return(j+y*4);
temp=_crol_(temp,1);
return 16;}
void judge()
P1=0xf0;
if(P1!=0xf0) //判断是否有按键
delay(50);
delay(50); //消抖
if(P1!=0xf0)
h=keyscan();
/*unsigned char a=1,i=0,k=0,l=1,m=1,n,f=0,s=0;
int q;*/
Initialize_LCD();
init();
Display_String(1,1,"Welcome To Use");
Display_String(2,1," ");
touch1=0;
/*//第一个while循环
judge();
if(h<10)
if(h==table[i])
k++;
Display_String(2,a,"*");
a++;
i++;
if(a==7)
a=1;
if(i==6)
i=0;
h=16;
if(h==14)
Display_String(1,1,"Input Password");
h=16;
touch=1;
touch1=0;
k=0;
l=1;
q=0;
if(h==12)
if(k==6)
Display_String(1,1,"Password Right");
Display_String(2,1,"Lock Opened!");
touch=!touch;
Display_String(1,1,"Password Error");
i=0;
q++;
while(q==3)
speaker=0;
delay(200);
delay(200);
delay(200);
speaker=1;
q=0;
h=14;
delay(255);
k=0;
h=16;
judge();
if(h==11)
{ Display_String(1,1,"New Code");
while(m==1)
judge();
touch1=!touch1;
if(h<10)
table[n]=h;
write_add(s,h);
s++;
a++;
n++;
h=16;
if(n==6)
n=0;
s=0;
if(h==15)
if(n==0)
n=6;
s=6;
a--;
s--;
Display_String(2,a," ");
n--;
h=16;
if(h==13)
m=0;
if(h==13)
h=13;
f=1;
if(h==14)
l=0;
if(h==13)
for(n=0;n<6;n++)
Display_char(2,n+1,(uchar)(table[n]+48));h=13;l=0,f=1;}
k=0;
if(h==15)
a--;
k--;
i--;
h=16;
if(h==13)
{ if(f==1)
{ for(n=0;n<6;n++)
Display_char(2,n+1,(uchar)(table[n]+48) );f=0;}
Display_String(2,1," ****** ");
delay(255);
delay(255);
Display_String(1,1," Welcome To Use ");
l=1,a=1;k=0;n=0;m=1;
h=16;
for(s=0;s<6;s++)
{ table[s]=read_add(s);
delay(50);
(122.04 KB, 下载次数: 44)
下载附件
2020-6-19 15:52 上传
电路图
