求助 用arduino 读取 mpu6050数据 结果串口一片白 编译上传都没啥问题
DLAM123
2020-6-23 17:16
#include <Wire.h>
long accelX,accelY,accelZ;
float gForceX,gForceY,gForceZ;
long gyroX,gyroY,gyroZ;
float rotX,rotY,rotZ;
void setupMPU(){
Wire.beginTransmission(0b1101000);
Wire.write(0x6B);
Wire.write(0b00000000);
Wire.endTransmission(true);
Wire.write(0x1B);
Wire.write(0x1C);
void recordAccelRegisters() {
Wire.write(0x3B);
Wire.requestFrom(0b1101000,6);
while(Wire.available()<6);
accelX = Wire.read()<<8|Wire.read();
accelY = Wire.read()<<8|Wire.read();
accelZ = Wire.read()<<8|Wire.read();
processAccelData();
void processAccelData(){
gForceX = accelX / 16384.0;
gForceY = accelY / 16384.0;
gForceZ = accelZ / 16384.0;
void recordGyroRegisters() {
Wire.write(0x43);
gyroX = Wire.read()<<8|Wire.read();
gyroY = Wire.read()<<8|Wire.read();
gyroZ = Wire.read()<<8|Wire.read();
processGyroData();
void processGyroData() {
rotX = gyroX / 131.0;
rotY = gyroY / 131.0;
rotZ = gyroZ / 131.0;
void printData(){
Serial.print("Gyro (deg)");
Serial.print(" X=");
Serial.print("rotX");
Serial.print(" Y=");
Serial.print("rotY");
Serial.print(" Z=");
Serial.print("rotZ");
Serial.print(" Accel (g)");
Serial.print("gForceX");
Serial.print("gForceY");
Serial.println("gForceZ");
void setup() {
Serial.begin(9600);
Wire.begin();
setupMPU();
void loop() {
recordAccelRegisters();
recordGyroRegisters();
printData();
delay(100);
DLAM123
2020-6-23 17:17
是程序哪里不对吗
