标题: 用PROTEUS仿真单片机与七段数码管 [打印本页]
作者: hasakei    时间: 2020-6-29 10:47
要求:用七段数码管显示数字0~9
原理图:
源代码:
#include<reg51.h>
voidcct_init(void);
voiddelay(int);
voidDisplayOn7Segment(char);
intmain(void)
   char ch = '0';           // Character to bedisplayed on 7seg
   cct_init();                  // Make all ports zero
      DisplayOn7Segment(ch);   //Display ch on 7seg
      delay(30000);                     // About 1sec delay
      switch(ch)                           // Update ch with new value to be displayed
             case '0': ch = '1';  break;
             case '1': ch = '2';  break;
             case '2': ch = '3';  break;
             case '3': ch = '4';  break;
             case '4': ch = '5';  break;
             case '5': ch = '6';  break;
             case '6': ch = '7';  break;
             case '7': ch = '8';  break;
             case '8': ch = '9';  break;
             case '9': ch = '0';  break;
             default: ch = '0';  break;
voidcct_init(void)
      P0 = 0x00;
      P1 = 0x00;
      P2 = 0x00;
      P3 = 0x00;
voiddelay(int a)
   int i;
   for(i=0;i<a;i++);   //null statement
voidDisplayOn7Segment(char ch)   // ch canhave a value from '0' to 'F' only
      switch(ch)
                    case '0': P2= 0x3F;  break;
       case'1':  P2 = 0x06;  break;
       case'2':  P2 = 0x5B;  break;
       case'3':  P2 = 0x4F;  break;
       case'4':  P2 = 0x66;  break;
       case'5':  P2 = 0x6D;  break;
       case'6':  P2 = 0x7D;  break;
       case'7':  P2 = 0x07;  break;
       case'8':  P2 = 0x7F;  break;
       case'9':  P2 = 0x6F;  break;
       default:P2 = 0x3F;  break;
仿真结果:
