DATA SEGMENT ;数据段
MESS DB 'PRESS ANY KEY TO EXIT',0AH,0DH,'$'
TAB DB 3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH,77H,7CH,39H,5EH,79H,71H,76H
INT_SEG DW ?
INT_OFF DW ?
INTSOR DB ?
FLA DB 0
DATA ENDS
STACK SEGMENT ;堆栈段
STA DW 512 DUP(?)
STACK ENDS
CODE SEGMENT ;代码段
ASSUME CS:CODE,DS:DATA,SS:STACK
START:MOV AX,DATA
MOV DS,AX
MOV AX,STACK
MOV SS,AX
MOV SP,SIZE STA
MOV CL,0
MOV DX,0283H 8253和8255的初始化
MOV AL,36H
OUT DX,AL
MOV DX,0280H ;8253初始化
MOV AL,0E8H
OUT DX,AL
MOV AL,03H
OUT DX,AL
MOV DX,0283H
MOV AL,76H
OUT DX,AL
MOV DX,0281H
MOV AL,0E8H
OUT DX,AL
MOV AL,03H
OUT DX,AL
MOV DX,028BH ;8255初始化
MOV AL,90H
OUT DX,AL
MOV AL,0BH
MOV AH,35H ;取该中断向量
INT 21H
MOV INT_SEG,ES ;保存向量段基址
MOV INT_OFF,BX ;保存向量偏移量
CLI ;修改向量前关中断
PUSH DS
;填写中断向量表
MOV AX,SEG INT_PR
MOV DS,AX
MOV DX,OFFSET INT_PR
MOV AL,0BH
MOV AH,25H
INT 21H
IN AL,21H
MOV INTSOR,AL ;保护原中断屏蔽字
AND AL,0F7H ;开放中断请求
OUT 21H,AL ;开中断
POP DS
STI
LEA DX,MESS
MOV AH,09H
INT 21H
STI
LOOPA:
HLT
MOV AH,01H
INT 16H
JZ LOOPA
CLI
MOV AX,INT_SEG
MOV DS,AX ;DS指向向量段基址
MOV DX,INT_OFF ;DX指向向量偏移量
MOV AL,0BH
MOV AH,25H ;恢复中断向量
INT 21H
MOV AL,INTSOR ;恢复原中断屏蔽字
OUT 21H,AL
STI
;中断子程序
INT_PR PROC
PUSH DS
STI
MOV DX,0288H
IN AL,DX
CMP AL,0FH
JA LOP1 ;大于0fh跳转至lop1
MOV BX, OFFSET TAB ;display 低四位
XLAT ;查表
JMP LOP3
