单片机履带车程序求助
yqq56
2020-7-30 16:35
单片机履带车程序求助
本人单片机新手,做了一个履带车,必须七个遥控功能,前进,后退,加速,减速,左转,右转还有停车。使用PT2272M6最多六个通道,设想在pt2262遥控的前进键用软件(51单片机)实现按一下前进,再按一下停车,按说很简单的程序我就是弄不好,哪位专业师傅给帮我弄一下,不胜感谢。下面是源程序,K1是前进键,K5是停止键。
#include <reg52.h>
typedef unsigned char u8;
typedef unsigned int u16;
//L298N????
sbit ena = P0^0;
sbit in1 = P0^1;
sbit in2 = P0^2;
sbit in3 = P0^3;
sbit in4 = P0^4;
sbit enb = P0^5;
sbit key1 = P3^3; //????
sbit key2 = P3^4; //????
sbit key3 = P3^6; //????
sbit key4 = P3^7;
sbit key5 = P2^0;
sbit key6 = P2^1;
sbit key7 = P2^2;
sbit key8 = P2^3;
sbit relay = P2^4;//????
u16 MA = 0,MB = 0; //pwm???
u16 SpeedA = 20; //50%???
u16 SpeedB = 20;
u8 flag; //??,1????,0????
//???????sbuf
void delay(u16 z); //??????
void forward()
flag = 1; //??????
in1=1; //l298n??
in2=0;
in3=1;
in4=0;
void fallback()
flag = 0; //??????
in1=0;
in2=1;
in3=0;
in4=1;
void quick()
SpeedA += 1; //???1
if(SpeedA >= 40) //??40
SpeedA = 40;
SpeedB += 1;
if(SpeedB >= 40)
SpeedB = 40;
void slow()
SpeedA -= 1; //???1
if(SpeedA <= 5)//??5
SpeedA = 5;
SpeedB -= 1;
if(SpeedB <= 5)
SpeedB = 5;
void move_left()
in1=1;
in2=0;
in3=0;
in4=0;
void move_right()
in1=0;
in2=0;
in3=1;
in4=0;
void stop()
in1=0;
in2=0;
in3=0;
in4=0;
void delay(u16 z)
u16 x,y;
for(x=z;x>0;x--)
for(y=125;y>0;y--);
//????? ???T0
TMOD = 0x21; //T0?????????,T1?????????
//PCON = 0x00; //???????,???
//SCON = 0x50; //???????,???????,????
TH1 = 0xFD; //????
TL1 = 0xFD; //????
//TR1 = 1; //?????T1
TH0 = 0xF4; //????
TL0 = 0x48; //????
TR0 = 1; //?????T0
//ES = 1;//??????
//PS = 1; //??????
//PT0 = 1; //???0????
ET0 = 1;//?????T0??
EA = 1;//?????
if(key1 == 0)
delay(10);
if(key1 == 0)
forward();
while(key1 == 0);
if(key2 == 0)
delay(10);
if(key2 == 0)
fallback();
while(key2 == 0);
if(key3 == 0)
delay(10);
if(key3 == 0)
quick();
while(key3 == 0);
if(key4 == 0)
delay(10);
if(key4 == 0)
slow();
while(key4 == 0);
if(key5 == 0)
delay(10);
if(key5 == 0)
stop();
while(key5 == 0);
if(key6 == 0)
delay(10);
if(key6 == 0)
move_left();
while(key6 == 0);
if(key7 == 0)
delay(10);
if(key7 == 0)
move_right();
while(key7 == 0);
if(key8 == 0)
delay(10);
if(key8 == 0)
relay=~relay;
while(!key8);
void time0_int() interrupt 1 //T = 3ms * 40 = 120ms
TR0 = 0;
TH0 = 0xF4;
TL0 = 0x48; //3000; 3ms
MA++;
if(MA < SpeedA)
ena = 1;
ena = 0;
if(MA == 40)
MA = 0;
MB++;
if(MB < SpeedB)
enb = 1;
enb = 0;
if(MB == 40)
MB = 0;
TR0 = 1;
gbchang
2020-7-30 17:34
我假设你车辆控制程序都正常了,只是这个按键逻辑搞不定,给出如下建议:
设计档位概念,共 5 档:前进2档,前进1档,停车0档,后退-1档,后退-2档
key1 升档, key2 降档,key3/key4空闲,key5停车保留
可以通过连续按 key1 从-2档一直升到+2档,key2同理
代码如下:
static char speed=0;
if(key1 == 0)
delay(10);
if(key1 == 0)
if(++speed > 2)speed = 2;
while(key1 == 0);
if(key2 == 0)
delay(10);
if(key2 == 0)
if(--speed < -2)speed = -2;
while(key2 == 0);
if(key3 == 0)
delay(10);
if(key3 == 0)
while(key3 == 0);
if(key4 == 0)
delay(10);
if(key4 == 0)
while(key4 == 0);
if(key5 == 0)
delay(10);
if(key5 == 0)
stop();
while(key5 == 0);
if(key6 == 0)
delay(10);
if(key6 == 0)
move_left();
while(key6 == 0);
if(key7 == 0)
delay(10);
if(key7 == 0)
move_right();
while(key7 == 0);
if(key8 == 0)
delay(10);
if(key8 == 0)
relay=~relay;
while(!key8);
//根据速度代码输出
switch( speed )
case 2:
//高速前进
quick();
break;
case 1:
//低速前进
forward();
slow();
break;
case 0:
//停车
stop();
break;
case -1:
//低速后退
fallback();
slow();
break;
case -2:
//高速后退
quick();
break;
default:
speed=0;
break;
yqq56
2020-7-30 20:33
设计档位概念,共 5 档:前进2档 ...
谢谢这么快就回复了,你的这个思路和程序很好,我马上调试程序,再次谢谢!谢谢!
