标题: 单片机LCD12864滚动和反白显示图片源程序+Proteus仿真 [打印本页]
作者: 1236222    时间: 2020-7-31 10:44
本任务是用单片机实现液晶显示演示效果如图所示。通过编程,学会在单片机上实现液晶显示控制方法,以及不同数据显示的程序编写方法。
  1. #include "LCD_12864.h"
  2. #include <stdio.h>
  3. extern void cls();
  4. extern uchar LCD_Initialise();
  5. extern uchar LCD_Write_Command(uchar cmd);
  6. extern uchar LCD_Write_Command_P2(uchar cmd,uchar para1,uchar para2);
  7. extern uchar LCD_Write_Data(uchar dat);
  8. extern void Set_LCD_POS(uchar row,uchar col);
  9. extern uchar code LCD_WIDTH;
  10. extern uchar code LCD_HEIGHT;
  11. sbit S1 = P1^0;
  12. sbit S2 = P1^1;
  13. uchar code ImageX[] =
  14. {
  15.         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
  16. };
  17. void main()
  18. {
  19.         uchar i,j,m;
  20.         uint k,x;
  21.         LCD_Initialise();
  22.         Set_LCD_POS(0,0);
  23.         cls();
  24.         while(1)
  25.         {
  26.                  if(S1!=0)
  27.                 {
  28.                          LCD_Write_Command_P2(LC_GRH_STP,0,0);
  29.                         for(i=0;i<LCD_HEIGHT;i++)
  30.                         {
  31.                                  Set_LCD_POS(i,0);
  32.                                 LCD_Write_Command(LC_AUT_WR);
  33.                                 for(j=0;j<LCD_WIDTH;j++)
  34.                                 {
  35.                                          m = ImageX[i*LCD_WIDTH + j];
  36.                                         if(S2 == 0)
  37.                                                 m = ~m;
  38.                                         LCD_Write_Data(m);
  39.                                 }
  40.                                 LCD_Write_Command(LC_AUT_OVR);
  41.                         }
  42.                 }
  43.                 else
  44.                 {
  45.                          k = 0;
  46.                         while(k!=128/8*LCD_HEIGHT)
  47.                         {
  48.                                 LCD_Write_Command_P2(LC_GRH_STP,k%256,k/256);
  49.                                 for(x=0;x<5000;x++);
  50.                                 k+=LCD_WIDTH;
  51.                         }
  52.                 }
  53.         }
  54.         for(x=0;x<40000;x++);
  55. }
12864LCD图形滚动演示.zip (99.85 KB, 下载次数: 58)
