标题: 《龙与地下城》d20任务系统人物数据设定C++源程序 [打印本页]
作者: nzl    时间: 2020-8-2 16:33
这个是我根据《龙与地下城》d20任务系统写的一个人物设定小程序
全部资料51hei下载地址:
设定.rar (369.42 KB, 下载次数: 6)
源程序如下:
  1. #include<bits/stdc++.h>
  2. using namespace std;
  3. int lx(double);
  4. int xb(double);
  5. int main()
  6. {
  7.         ofstream fout("out.txt");
  8.         bool sex;
  9.         double t;
  10.         double str=0,con=0,dex=0,chr=0,wis=0,inz=0;
  11.         t=rand()/double(RAND_MAX);
  12.         if(lx(t))
  13.         {
  14.                 str=(rand()%(18-1+1))+1;
  15.                 fout<<"力量:"<<str<<endl;
  16.         }
  17.         else
  18.         {
  19.                 str=((double)rand()/RAND_MAX)*(2-0.3)+0.3;
  20.                 fout<<"力量:"<<str<<"x"<<endl;
  21.         }
  22.         t=rand()/double(RAND_MAX);
  23.         if(lx(t))
  24.         {
  25.                 con=(rand()%(18-1+1))+1;
  26.                 fout<<"体质:"<<con<<endl;
  27.         }
  28.         else
  29.         {
  30.                 con=((double)rand()/RAND_MAX)*(2-0.3)+0.3;
  31.                 fout<<"体质:"<<con<<"x"<<endl;
  32.         }
  33.         t=rand()/double(RAND_MAX);
  34.         if(lx(t))
  35.         {
  36.                 dex=(rand()%(18-1+1))+1;
  37.                 fout<<"敏捷:"<<dex<<endl;
  38.         }
  39.         else
  40.         {
  41.                 dex=((double)rand()/RAND_MAX)*(2-0.3)+0.3;
  42.                 fout<<"敏捷:"<<dex<<"x"<<endl;
  43.         }
  44.         t=rand()/double(RAND_MAX);
  45.         if(lx(t))
  46.         {
  47.                 chr=(rand()%(18-1+1))+1;
  48.                 fout<<"魅力:"<<chr<<endl;
  49.         }
  50.         else
  51.         {
  52.                 chr=((double)rand()/RAND_MAX)*(2-0.3)+0.3;
  53.                 fout<<"魅力:"<<chr<<"x"<<endl;
  54.         }
  55.         t=rand()/double(RAND_MAX);
  56.         if(lx(t))
  57.         {
  58.                 wis=(rand()%(18-1+1))+1;
  59.                 fout<<"智力:"<<wis<<endl;
  60.         }
  61.         else
  62.         {
  63.                 wis=((double)rand()/RAND_MAX)*(2-0.3)+0.3;
  64.                 fout<<"智力:"<<wis<<"x"<<endl;
  65.         }
  66.         t=rand()/double(RAND_MAX);
  67.         if(lx(t))
  68.         {
  69.                 inz=(rand()%(18-1+1))+1;
  70.                 fout<<"知觉:"<<inz<<endl;
  71.         }
  72.         else
  73.         {
  74.                 inz=((double)rand()/RAND_MAX)*(2-0.3)+0.3;
  75.                 fout<<"知觉:"<<inz<<"x"<<endl;
  76.         }
  77.         t=rand()/double(RAND_MAX);
  78.         if(xb(t))
  79.                 fout<<"性别:男"<<endl;
  80.         else
  81.                 fout<<"性别:女"<<endl;
  82.         fout.close();
  83.         return 0;
  84. }
  85. int lx(double n)
  86. {
  87.         if(n>=0.1)
  88.                 return 1;
  89.         else
  90.                 return 0;
  91. }
  92. int xb(double d)
  93. {
  94.         if(d>=0.51)
  95.                 return 1;
  96.         if(d<=0.49)
  97.                 return 0;
  98. }
作者: buibui~l    时间: 2020-8-5 22:09
这个是用什么编译软件写的
作者: npn    时间: 2020-8-5 22:48
buibui~l 发表于 2020-8-5 22:09
这个是用什么编译软件写的
visual studio就可以
