标题: 求问,485通信串口助手只能接受到stm32发送的第一节数据 [打印本页]
作者: NATIRO    时间: 2020-8-5 09:22
程序如下:
void bsp_RS485_IRQHandler(void)
   if(USART_GetITStatus(RS485_usart, USART_IT_ORE)==SET)
    USART_ClearITPendingBit(RS485_usart, USART_IT_ORE);
    USART_ReceiveData(RS485_usart);
        if(USART_GetITStatus(RS485_usart, USART_IT_RXNE) != RESET)
            uart_buff[uart_p] = USART_ReceiveData(RS485_usart);
            uart_p++;
      USART_ClearITPendingBit(RS485_usart, USART_IT_RXNE);
    if(uart_p == 9)
     recivestate = 1;
     len = uart_p;
     for(i = 0;i<uart_p;i++)//&acute;&laquo;&sup3;&ouml;&Ecirc;&yacute;&frac34;&Yacute;
        uart_rx_buff[i] = uart_buff[i];
     //clean_rebuff();
     RS485_init();
u16 sum=0;
void test()
u8 txbuff[1024];
u8 buff[2] = {0x01,0x02};
u16 i,cnt = 0;
if(recivestate == 1)
  recivestate = 0;
  for(i=1;i<len-4;i++)
  sum += uart_rx_buff[i];
   if(uart_rx_buff[cnt] == title1_send && uart_rx_buff[cnt+1] == title2_send)
    if(uart_rx_buff[cnt+5] == (sum&0xff) && uart_rx_buff[cnt+6] == ((sum>>8)&0xff))
      switch(uart_rx_buff[cnt+2])
     case 0x08: //选择功能
      RS485_TX_EN();
      RESEND(0x08,len);
     //RS485_delay(10000);
       RS485_RX_EN();
       break;
void RESEND(u8 cmd,u8 L)
u8 data_send[50];
u8 cnt = 0;
u16 i ,sum;
data_send[cnt++] = title1_send;
data_send[cnt++] = title2_send;
data_send[cnt++] = cmd;
data_send[cnt++] = L;
for(i=1;i<L-4;i++)
  sum += data_send[i];
data_send[cnt++] = (sum&0xff);
data_send[cnt++] = ((sum>>8)&0xff);
data_send[cnt++] = 0X0D;
data_send[cnt++] = 0X0A;
  USART_send_array(RS485_usart,data_send,cnt-1);
void USART_send_array(USART_TypeDef *pUSARTx,u8 *array,u8 len)
u8 i=0;
while(i<len)
USART_SendData(pUSARTx,array[i]);
  while( USART_GetFlagStatus(pUSARTx,USART_FLAG_TC)!= SET);
i++;
配置文件
void RS485_configure()
    USART_InitTypeDef USART_InitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    RCC_APB2PeriphClockCmd(RS485_usart_clk,ENABLE);
    RCC_APB2PeriphClockCmd(RS485_USART_RX_GPIO_CLK,ENABLE);
    RCC_APB2PeriphClockCmd(RS485_USART_TX_GPIO_CLK,ENABLE);
    RCC_APB2PeriphClockCmd(RS485_USART_PE_GPIO_CLK,ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
    GPIO_InitStructure.GPIO_Pin=RS485_usart_TX_PIN;
    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
    GPIO_Init(RS485_USART_TX_GPIO_PORT,&GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin=RS485_usart_RX_pin;
    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
    GPIO_Init(RS485_USART_RX_GPIO_PORT,&GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin=RS485_RE_PIN;
    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
    GPIO_Init(RS485_RE_GPIO_PORT,&GPIO_InitStructure);
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
    NVIC_InitStructure.NVIC_IRQChannel = RS485_INT_IRQ;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
   USART_ITConfig(RS485_usart, USART_IT_RXNE, ENABLE);
   USART_ITConfig(RS485_usart, USART_IT_IDLE, ENABLE);
   USART_ITConfig(RS485_usart, USART_IT_ORE, ENABLE);
    GPIO_ResetBits(RS485_RE_GPIO_PORT,RS485_RE_PIN);
中断里接收到的数据是完整的,比如接收到了3A 16 08 01 00 .... 0D 0A,我想mcu返回3A 16 09 02.....,全速运行后结果只返回了一个3A,然后程序卡住了,之后再怎么发都不返回了,停下来就发现一直在中断里面。我查了下数据,数据也有传到uart_rx_buff[]里面了。求各位大神帮帮忙!!!!!!(还有一点,我按照网上的说法在发送后面加了个延时函数,就发送了3A 16,之后无论怎么加大延时函数也是发这两个。)
作者: 飘零111    时间: 2021-1-8 09:29
中断里面加延时会跑飞
