基于STM32LCD多级菜单显示
Y志伟
2020-10-2 19:14
基于STM32LCD多级菜单显示
主函数程序如下:
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "beep.h"
#include "key.h"
#include "timer.h"
#include "lcd.h"
#include "menu.h"
#include "opencv_uart.h"
int main(void)
uint8_t key_value;
uint32_t main_time,key_time;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
delay_init(168); //初始化延时函数
uart_init(115200); //初始化串口波特率为115200
usart2_init(115200);
TIMER2_Init();
LED_Init(); //初始化LED
KEY_Init();
LCD_Init(); //初始化LCD FSMC接口
POINT_COLOR=RED; //画笔颜色:红色
SetDefaultMenuHandler(Str_Test);//设置功能函数
Thebeginningoftheinterface();
if(KEY_UP==0)
break;
delay_ms(200);
DispCrtMenu(); //将主菜单页面先显示,去掉此句进入为黑屏
main_time = Get_RunTime(); //获取系统时间
if(main_time > key_time) //按键扫描,10毫秒1次
key_time = main_time;
key_value = KEY_Scan(0);
if(key_value!=0xff)
Display(key_value);
menu.c文件如下:
#include "menu.h"
#include <stdio.h>
#include "string.h"
#include "lcd.h"
#include "key.h"
#include "led.h"
#include "delay.h"
#include "image.h"
#include "picture.h"
//各级菜单页面结构体声明
Menu menu1_main[5];
Menu menu2_file[4];
Menu menu2_edit[4];
Menu menu2_view[4];
Menu menu2_set[3];
Menu menu3_test[2];
//结构体初始化//菜单定义,在这里将每一个菜单的关联设置好
Menu menu1_main[5] = // 第1级 主菜单
{5, "主菜单", "文件 >>", TYPE_SUBMENU, NULL, menu2_file, NULL},
{5, "", "编辑 >>", TYPE_SUBMENU, NULL, menu2_edit, NULL},
{5, "", "视图 >>", TYPE_SUBMENU, NULL, menu2_view, NULL},
{5, "", "设置 >>", TYPE_SUBMENU, NULL, menu2_set, NULL},
{5, "", "帮助 --", TYPE_PARAM, NULL, NULL, NULL},
Menu menu2_file[4] = // 第2级 文件菜单
{4, "文件", "open ", TYPE_SUBMENU, NULL, NULL, menu1_main},
{4, "", "close ", TYPE_SUBMENU, NULL, NULL, menu1_main},
{4, "", "save ", TYPE_SUBMENU, NULL, NULL, menu1_main},
{4, "", "exit ", TYPE_SUBMENU, NULL, NULL, menu1_main},
Menu menu2_edit[4] = // 第2级 编辑菜单
{4, "编辑", "cut ", TYPE_SUBMENU, NULL, NULL, menu1_main},
{4, "", "copy ", TYPE_SUBMENU, NULL, NULL, menu1_main},
{4, "", "paste ", TYPE_SUBMENU, NULL, NULL, menu1_main},
{4, "", "delete ", TYPE_SUBMENU, NULL, NULL, menu1_main},
Menu menu2_view[4] = // 第2级 视图菜单
// {4, "视图", "open ", TYPE_SUBMENU, NULL, NULL, menu1_main},
{4, "视图", "open ", TYPE_PARAM, NULL, NULL, menu1_main},
{4, "", "close ", TYPE_PARAM, NULL, NULL, menu1_main},
{4, "", "ColorText ", TYPE_PARAM, NULL, NULL, menu1_main},
Menu menu2_set[3] = // 第2级 设置菜单
{3, "设置", "option ", TYPE_SUBMENU, NULL, NULL, menu1_main},
{3, "", "set ", NULL, NULL, NULL, menu1_main},
{3, "", "on/off test ", TYPE_SUBMENU, NULL, menu3_test, menu1_main},
// {3, "", "on/off test ", TYPE_SUBMENU, NULL, NULL, menu1_main},
Menu menu3_test[2] = // 第3级菜单,menu_tool子菜单
{2, "Text", "ON ", TYPE_PARAM, NULL, NULL, menu2_set},
{2, "", "OFF ", TYPE_PARAM, NULL, NULL, menu2_set},
//颜色测试函数,作为菜单中一个子功能,移植时可以删除
void Test_Color()
u16 ColorTab[8]= {WHITE,BRED,BROWN,YELLOW,BLUE,RED,GREEN,GRAY};//定义颜色数组
char *ColorText[] = {"WHITE","BRED","BROWN","YELLOW","BLUE","RED","GREEN","GRAY"};
//绘制显示区域
LCD_Fill(0,40,lcddev.width,lcddev.height-40,BLACK);
for(u8 i=0;i<=7;i++)
LCD_Fill(90,250,390,550,ColorTab[i]);
Gui_StrCenter(0,220,(u8 *)ColorText[i],24,1);delay_ms(1000);
//各项功能函数
void Str_Test(const char *str)
POINT_COLOR = WHITE;
if(strstr((char *)str,"帮助"))
LCD_Fill(0,lcddev.height-40,lcddev.width,lcddev.height,BLUE);
Gui_StrCenter(0,lcddev.height-32,"菜单测试程序",24,1);//居中显示
if(strstr((char *)str,"ColorText"))
Gui_StrCenter(0,lcddev.height-32,"ColorText",24,1);//居中显示
Test_Color();
if(strstr((char *)str,"ON"))
LED01_ON(); //实际功能函数
Gui_StrCenter(0,lcddev.height-32,"LED已打开",24,1);//居中显示
if(strstr((char *)str,"OFF"))
LED01_OFF(); //实际功能函数 LED0 LED1关闭
Gui_StrCenter(0,lcddev.height-32,"LED已关闭",24,1);//居中显示
if(strstr((char *)str,"open"))
if(strstr((char *)str,"close"))
//设置相应项按确定键后执行的函数
//将上面的功能函数 赋值到各功能项
void SetDefaultMenuHandler(MENU_FUN pFun)
menu1_main[4].Function = pFun;
menu2_view[3].Function = pFun;
menu2_view[1].Function = pFun;
menu2_view[0].Function = pFun;
menu3_test[0].Function = pFun;
menu3_test[1].Function = pFun;
//定义菜单操作需要的全局变量
Menu *cur_item = menu1_main; //初始化当前菜单为第一级(main_menu)
Menu *prev_item = NULL; //初始化上一级菜单为空
uint8_t item_index = 0;//当前菜单项索引
//绘制测试界面
//str :字符串指针
void DrawTestPage(u8 *str)
//绘制固定栏up
LCD_Fill(0,0,lcddev.width,40,BLUE);
//绘制固定栏down
POINT_COLOR=WHITE;
Gui_StrCenter(0,9,str,24,1); //菜单顶部标题 居中显示
Gui_StrCenter(0,lcddev.height-32,"",24,1);//菜单底部 居中显示
POINT_COLOR=RED;
LCD_ShowString(10,lcddev.height-32,100,30,24, "右键确定",0);
LCD_ShowString(374,lcddev.height-32,100,30,24, "左键取消",0);
//绘制显示区域
void Thebeginningoftheinterface()
u8 lcd_id[]="20181106074";
// LCD_ShowString(40,40,200,24,24,"Explorer STM32F4",0);
LCD_ShowString(45,40,200,30,24,"武昌首义学院",0);
// LCD_ShowString(20,90,200,16,16,lcd_id,0);
LCD_ShowString(65,80,200,16,24,"2020/9/18",0);
//LCD_ShowString(20,150,200,30,24,"武昌首义学院",0); //30,300,200,30,24
LCD_ShowString(20,120,200,30,24,"作者:熊明炜",0);
LCD_ShowString(20,150,200,30,24,"作者:杨志伟",0);
LCD_ShowString(20,180,200,30,24,"作者:舒 淦",0);
LCD_ShowString(20,230,100,30,24, "右键进入",0);
image_display(310,168,(u8*)gImage_1);//在指定地址显示图片
//image_display(310,450,(u8*)gImage_2);//在指定地址显示图片
void DispCrtMenu(void)//绘制当前菜单项
uint8_t menu_num = cur_item[0].num;//获取当前菜单的项目数量
uint8_t i, num = menu_num>MENU_MAX_ROW ? MENU_MAX_ROW : menu_num;//绘制数量不能超过每一屏的最大绘制数量
if(item_index>=MENU_MAX_ROW || item_index>=menu_num)//菜单项上下选择是否越界
if(item_index==0XFF) //此情况为 item_index=0 再按上键,0-1=0XFF
item_index = menu_num - 1; //循环,回到最后一个功能索引值
if(item_index>=menu_num) //此情况为到达最下面一个功能索引值
item_index = 0; //循环,回到第一个功能索引值
if(item_index>=MENU_MAX_ROW)
item_index = 0;
DrawTestPage((u8 *)cur_item[0].title);
for (i=0; i<num; i++)//绘制某一级菜单下的功能键
POINT_COLOR = RED;
//Show_Str_1(0, (i+1)*40, (u8 *)cur_item[i].label, 32, i==item_index ? 0:1);//绘制单个菜单项
LCD_ShowString(144,150+(i+1)*40,200,30,24, (u8 *)cur_item[i].label,i==item_index ? 0:1);
#define KEY_ENTER_PRESS 3 //对应原子开发板的左键
#define KEY_RETURN_PRESS 4 //对应原子F4板的右键
void Display(uint8_t value)
if(value==KEY_UP_PRESS || value==KEY_DOWN_PRESS || value==KEY_ENTER_PRESS || value==KEY_RETURN_PRESS)
switch(value)//检测按键,进入相应动作
case KEY_UP_PRESS:
item_index--;
DispCrtMenu();
break;
case KEY_DOWN_PRESS:
item_index++;
DispCrtMenu();
break;
case KEY_ENTER_PRESS:
switch(cur_item[item_index].type)//检测功能项的类型,进入相应动作
case TYPE_SUBMENU: //具有子菜单的菜单项
if(cur_item[item_index].next != NULL)
prev_item = cur_item;//此级菜单变成了上一级菜单
cur_item = cur_item[item_index].next;//将指向的下一级菜单设置为当前菜单
item_index = 0;//重置子菜单项索引
DispCrtMenu();
Gui_StrCenter(0,lcddev.height-32,"待设置~~~",24,1);//居中显示
PFout(9)=0;
delay_ms(1000);
PFout(9)=1;
break;
case TYPE_PARAM: //具有参数设置的菜单项
if(cur_item[item_index].Function != NULL)
//调用相应的动作函数,并传递参数
cur_item[item_index].Function((const char *)cur_item[item_index].label);
break;
default:
break;
break;
case KEY_RETURN_PRESS:
if (prev_item != NULL)//返回上一级菜单的操作
cur_item = prev_item; //设置上一级菜单为当前菜单
prev_item = cur_item[0].prev; //设置当前菜单的上一级菜单
item_index = 0; //重置子菜单项索引
DispCrtMenu();
Gui_StrCenter(0,lcddev.height-32,"已是主菜单",24,1);//居中显示
break;
default:
break;
