Keil编译错误ERROR A9:SYNTAX ERROR
晓风丶
2020-10-26 20:04
ERROR A9:SYNTAX ERROR这是啥情况
(49.84 KB, 下载次数: 50)
下载附件
2020-10-26 20:04 上传
晓风丶
2020-10-26 20:05
#include "reg52.h"
typedef unsigned int u16;
typedef unsigned char u8;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
#define GPIO_DIG P0
#define GPIO_KEY P1
u8 KeyValue;
u8 code smgduan[17]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
void delay(u16 i)
while(i--);
void KeyDown(void)
char a=0;
GPIO_KEY=0x0f;
if(GPIO_KEY!=0x0f)
delay(1000);
if(GPIO_KEY!=0x0f)/
GPIO_KEY=0X0F;
switch(GPIO_KEY)
case(0X07): KeyValue=0;break;
case(0X0b): KeyValue=1;break;
case(0X0d): KeyValue=2;break;
case(0X0e): KeyValue=3;break;
GPIO_KEY=0XF0;
switch(GPIO_KEY)
case(0X70): KeyValue=KeyValue;break;
case(0Xb0): KeyValue=KeyValue+4;break;
case(0Xd0): KeyValue=KeyValue+8;break;
case(0Xe0): KeyValue=KeyValue+12;break;
while((a<50)&&(GPIO_KEY!=0xf0))
delay(100);
a++;
LSA=0;
LSB=1;
LSC=1;
KeyDown();
GPIO_DIG=~smgduan[KeyValue];
这是源程序 运行显示/旁有错误应该为__asm 我就加了 也够了两个lrc 还是错误
MikeCai
2020-10-27 08:51
打开KEIL行号[点击Edit-->Configuration。然后会弹出一个名为Configuration 的窗口,勾选 show line number],来定位出错具体位置,就好简单,syntax error, 即符号错了
cheney03
2020-10-27 23:16
if(GPIO_KEY!=0x0f)/这句有错,去掉/
