标题: 这个单片机程序长按起作用,双击和单击都不行,求各位大佬帮帮忙 [打印本页]
作者: dcjdcj    时间: 2020-11-8 22:16
#include "ALL.H"
u8 NUM=0;
u8 key_N=0;
enum key_state
        key_state_0,
        key_state_1,
        key_state_2,
        key_state_3,
enum key_val
        key_click=0x80,
        key_double=0x40,
        key_long=0x20,
        key_value_1=0x0d,                        // 0000 1101
        key_value_2=0x0e,                        // 0000 1110
        key_value_3=0x0b,                        // 0000 1011
        key_value_4=0x07,                        // 0000 0111
        key_null=0x0f,
        key_long_period=200,
        key_continue_period=25,
void keyinit(void)
        key_1=1;
        key_2=1;
        key_3=1;
        key_4=1;
static u8 keyscan(void)
        if(!key_1)return key_value_1;
        if(!key_2)return key_value_2;
        if(!key_3)return key_value_3;
        if(!key_4)return key_value_4;
        return key_null;
void  Key_Driver(u8 *key_value)
        static u8 key_state_buffer1=key_state_0;
        static u8 key_timer_cnt1;
        u8 key_buffer=key_null;
        u8 key=keyscan();
        switch(key_state_buffer1)
                case key_state_0:
                        if(key_null!=key)
                                key_state_buffer1=key_state_1;
                        break;
                case key_state_1:
                        if(key_null!=key)
                                key_timer_cnt1=0;
                                key_state_buffer1=key_state_2;
                        break;
                case key_state_2:
                        if(key_null==key)
                                key_buffer=key;
                                key|=key_click;
                        else if(++key_timer_cnt1>=100)
                                key|=key_long;
                                key_state_buffer1=key_state_3;
                        break;
                case key_state_3:
                        if(key_null==key)
                        break;
        *key_value = key;
void Key_Read(u8 *key_value)
        static u8 key_state_buffer2=key_state_0;
        static u8 key_timer_cnt2=0;
        u8 *ptemp;
        u8 key_buffer=key_null;                       //0x0f
        u8 key;
        Key_Driver(ptemp);
        ptemp=&key;
        switch(key_state_buffer2)
                case key_state_0:
                        if(key==(key|key_click))
                                key_timer_cnt2=0;
                                key_state_buffer2=key_state_1;
                                s6=~s6;
                                key_value = &key;
                        break;
                case key_state_1:
                                key|=key_double;
                                s8=~s8;
                        else if(++key_timer_cnt2>=25)
                                key|=key_click;
                                s7=~s7;
                        break;
        *key_value = key;
void Key_Allot()
        u8 key=key_null;
        u8 *ptemp;
        if(flag)
                flag=0;                                                       //10ms定时
                Key_Read(ptemp);
                ptemp=&key;
                NUM=key;
                if(key==0x8d)   Min++;                                //        单击
                if(key==0x8e)   Min--;
                if(key==0x8b)   Sec=0;
                if(key==0x87)   Min=0;
                if(key==0x2d)   Hour++;                                //  长按
                if(key==0x2e)   Hour--;
                if(key==0x2b)   Hour=0;
                if(key==0x27)   Hour=24;
                if(key==0x4d)   Hour++;                                //  双击
                if(key==0x4e)   Hour--;
                if(key==0x4b)   Hour=0;
                if(key==0x47)   Hour=24;
作者: xianfajushi    时间: 2020-11-9 12:59
按键可参https://blog.csdn.net/xianfajushi/article/details/82281411
作者: dcjdcj    时间: 2020-11-9 19:54
不知道是不是这个函数不对,void Key_Read(u8 *key_value)   我用数码管线上void  Key_Driver(u8 *key_value)的值,是对的
作者: dcjdcj    时间: 2020-11-9 19:57
我用数码管显示void  Key_Driver(u8 *key_value)返回的值,是对的,调了几天了,一直找不到问题,我是新手小白一枚,请帮忙看看哪里出的问题,谢谢了
