标题: 单片机超声波测距加报警程序(频率可变)加报警距离可变 [打印本页]
作者: Yishi3    时间: 2020-11-13 15:45
8-元件清单.zip (6.85 KB, 下载次数: 37)
2-原理图(电路图).rar (160.17 KB, 下载次数: 47)
1-程序新.zip (48.04 KB, 下载次数: 46)
电路原理图如下:
  1. #include <reg52.H>//器件配置文件
  2. #include <intrins.h>
  3. #include "eeprom52.h"
  4. //传感器接口
  5. sbit RX  = P2^3;
  6. sbit TX  = P2^2;
  7. //按键声明
  8. sbit S1  = P1^4;
  9. sbit S2  = P1^5;
  10. sbit S3  = P1^6;
  11. sbit DIAN=P0^5;
  12. //蜂鸣器
  13. sbit Feng= P2^0;
  14. //变量声明
  15. unsigned int  time=0;
  16. unsigned int  timer=0;
  17. unsigned char posit=0;
  18. unsigned long S=0;
  19. unsigned long BJS;//报警距离
  20. char num=0;
  21. //模式 0正常模式 1调整
  22. char Mode=0;
  23. bit  flag=0,flag_BJ;
  24. unsigned char const discode[] ={0x5F,0x44,0x9D,0xD5,0xC6,0xD3,0xDB,0x47,0xDF,0xD7,0x80};        //数码管显示码0123456789-和不显示
  25. unsigned char disbuff[4]           ={0,0,0,0};                 //数组用于存放距离信息
  26. unsigned char disbuff_BJ[4]        ={0,0,0,0};//报警信息
  27. sbit W0=P2^4;
  28. sbit W1=P2^5;
  29. sbit W2=P2^6;
  30. sbit W3=P2^7;
  31. /******************把数据保存到单片机内部eeprom中******************/
  32. void write_eeprom()
  33. {
  34.         SectorErase(0x2000);
  35.         byte_write(0x2000, BJS%255);
  36.         byte_write(0x2001, BJS/255);
  37.         byte_write(0x2060, a_a);
  38. }
  39. /******************把数据从单片机内部eeprom中读出来*****************/
  40. void read_eeprom()
  41. {
  42.         BJS   = (byte_read(0x2001)*255)+byte_read(0x2000);
  43.         a_a      = byte_read(0x2060);
  44. }
  45. /**************开机自检eeprom初始化*****************/
  46. void init_eeprom()
  47. {
  48.         read_eeprom();                //先读
  49.         if(a_a != 1)                //新的单片机初始单片机内问eeprom
  50.         {
  51.                 BJS   = 40;
  52.                 a_a = 1;
  53.                 write_eeprom();           //保存数据
  54.         }
  55. }
  56. //延时100ms(不精确)
  57. void delay(void)
  58. {
  59.     unsigned char a,b,c;
  60.     for(c=10;c>0;c--)
  61.         for(b=38;b>0;b--)
  62.             for(a=130;a>0;a--);
  63. }
  64. //按键扫描
  65. void Key_()
  66. {
  67.         //+
  68.         if(S1==0)
  69.         {
  70.                 delay();           //延时去抖
  71.                 delay();           //延时去抖
  72.                 while(S1==0)
  73.                 {
  74.                         P1=P1|0x0f;
  75.                 }
  76.                         BJS++;         //报警值加
  77.                 if(BJS>500) //最大500
  78.                 {
  79.                         BJS=1;
  80.                 }
  81.                 write_eeprom();                           //保存数据
  82.         }
  83.         //-
  84.         else if(S2==0)
  85.         {
  86.                 delay();
  87.                 delay();           //延时去抖
  88.                 while(S2==0)
  89.                 {
  90.                         P1=P1|0x0f;
  91.                 }
  92.                         BJS--;         //报警值减
  93.                 if(BJS<1)         //最小1
  94.                 {
  95.                         BJS=500;
  96.                 }
  97.                 write_eeprom();                           //保存数据
  98.         }
  99.         //功能
  100.         else if(S3==0)                //设置键
  101.         {
  102.                 delay();
  103.                 delay();           //延时去抖
  104.                 while(S3==0)
  105.                 {
  106.                         P1=P1|0x0f;
  107.                 }
  108.                         Mode++;                //模式加
  109.                         num=0;
  110.                 if(Mode>=2)                //加到2时清零
  111.                 {
  112.                         Mode=0;
  113.                 }
  114.         }
  115. }
  116. /**********************************************************************************************************/
  117. //扫描数码管
  118. void Display(void)
  119. {
  120.         //正常显示
  121.         if(Mode==0)
  122.         {
  123.                 num++;
  124.                 if(num==1)
  125.                 {
  126.                         W3=1;
  127.                         W0=1;
  128.                         P0=~discode[disbuff[0]];
  129.                         DIAN=0;
  130.                         W1=0;
  131.                 }
  132.                 else if(num==2)
  133.                 {
  134.                         W1=1;
  135.                         P0=~discode[disbuff[1]];
  136.                         W2=0;
  137.                 }
  138.                 else if(num>=3)
  139.                 {
  140.                         W2=1;
  141.                         P0=~discode[disbuff[2]];
  142.                         W3=0;
  143.                         num=0;
  144.                 }
  145.         }
  146.         //报警显示
  147.         else
  148.         {
  149.                 num++;
  150.                 if(num==1)
  151.                 {
  152.                         W3=1;
  153.                         P0=~0xCE;                  //11001110
  154.                         W0=0;
  155.                 }
  156.                 else if(num==2)
  157.                 {
  158.                         W0=1;
  159.                         P0=~discode[disbuff_BJ[0]];
  160.                         DIAN=0;
  161.                         W1=0;
  162.                 }
  163.                 else if(num==3)
  164.                 {
  165.                         W1=1;
  166.                         P0=~discode[disbuff_BJ[1]];
  167.                         W2=0;
  168.                 }
  169.                 else if(num>=4)
  170.                 {
  171.                         W2=1;
  172.                         P0=~discode[disbuff_BJ[2]];
  173.                         W3=0;
  174.                         num=0;
  175.                 }
  176.         }
  177. }
  178. /**********************************************************************************************************/
  179. //计算
  180. void Conut(void)
  181. {
  182.         time=TH0*256+TL0;          //读出T0的计时数值
  183.         TH0=0;
  184.         TL0=0;                                  //清空计时器
  185.         S=(time*1.7)/100;     //算出来是CM
  186.         if(Mode==0)                          //非设置状态时
  187.         {
  188.                 if((S>=700)||flag==1) //超出测量范围显示“-”
  189.                 {
  190.                         flag=0;
  191.                         disbuff[0]=10;           //“-”
  192.                         disbuff[1]=10;           //“-”
  193.                         disbuff[2]=10;           //“-”
  194.                 }
  195.                 else
  196.                 {
  197.                         //距离小于报警距
  198.                         if(S<=BJS)                        //距离小于报警值
  199.                         {
  200.                                  flag_BJ=1;                //报警变量置一,定时器开始报警
  201.                         }
  202.                         else                                //距离大于报警值
  203.                         {
  204.                                 flag_BJ=0;                //关闭报警
  205.                                 Feng=1;                        //蜂鸣器关闭
  206.                         }
  207.                         disbuff[0]=S%1000/100;                 //将距离数据拆成单个位赋值
  208.                         disbuff[1]=S%100/10;
  209.                         disbuff[2]=S%10;
  210.                 }
  211.         }
  212.         else
  213.         {
  214.                         Feng=1;
  215.                         flag_BJ=0;                                                   //报警关闭
  216.                         disbuff_BJ[0]=BJS%1000/100;
  217.                         disbuff_BJ[1]=BJS%100/10;
  218.                         disbuff_BJ[2]=BJS%10;
  219.         }
  220. }
  221. /**********************************************************************************************************/
  222. //定时器0
  223. void zd0() interrupt 1                  //T0中断用来计数器溢出,超过测距范围
  224. {
  225.         flag=1;                                                 //中断溢出标志
  226. }
  227. /**********************************************************************************************************/
  228. //定时器1
  229. void zd3() interrupt 3                  //T1中断用来扫描数码管和计800MS启动模块
  230. {
  231.         unsigned int m;
  232.         TH1=0xf8;
  233.         TL1=0x30;                                 //定时2ms
  234.         Key_();                                        //扫描按键
  235.         Display();                                //扫描显示
  236.         timer++;                                //变量加
  237.         if(flag_BJ==1)                                  //报警开
  238.         {
  239.                 m++;                                          //2ms  m加一次
  240.                 if(m>=(S+10))                          //m的值大于等于距离加10
  241.                 {
  242.                         m=0;                                  //m清零
  243.                         Feng=!Feng;                          //蜂鸣器取反
  244.                 }
  245.         }
  246.         if(timer>=400)                        //400次就是800ms
  247.         {
  248.                 timer=0;
  249.                 TX=1;                                  //800MS  启动一次模块
  250.                 _nop_();
  251.                 _nop_();
  252.                 _nop_();
  253.                 _nop_();
  254.                 _nop_();
  255.                 _nop_();
  256.                 _nop_();
  257.                 _nop_();
  258.                 _nop_();
  259.                 _nop_();
  260.                 _nop_();
  261.                 _nop_();
  262.                 _nop_();
  263.                 _nop_();
  264. ……………………
  265. …………限于本文篇幅 余下代码请从51黑下载附件…………
作者: cuijb    时间: 2022-5-2 10:17
楼主程序有问题,搭了个电路点不亮
