八路抢答器程序和图
zhangxinzi
2020-12-17 21:58
八路抢答器程序和图
源程序
#include<reg52.h>
#define N 20
unsigned char code Tab[11]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf};
unsigned char int_time;
unsigned char second;
unsigned char num;
char flag1=0;
sbit K1=P1^0;
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
sbit K5=P1^4;
sbit K6=P1^5;
sbit K7=P1^6;
sbit K8=P1^7;
sbit B0=P3^6;
sbit KA=P3^0;
void delay(void)
int i;
for(i=0;i<3000;i++)
void DisplaySecond(unsigned char k)
P2=0xf7;
P0=Tab[k%10];
delay();
P0=0xff;
P2=0xfb;
P0=Tab[k/10];
delay();
P0=0xff;
P2=0xfd;
P0=Tab[10];
delay();
P0=0xff;
P2=0xfe;
P0=Tab[num];
delay();
P0=0xff;
void _reset()
if(KA==0)
delay();
if(KA==0)
flag1=1;
if(flag1)
//flag1=0;
break;
void key()
if(K1==0)
delay();
if(K1==0)
//void _stop();
num=1;
B0=1;
DisplaySecond(N-second);
P2=0xfe;
P0=Tab[num];
while(!K1);
_reset();
if(K2==0)
delay();
if(K2==0)
//void _stop();
num=2;
B0=1;
P2=0xfe;
P0=Tab[num];
while(!K2);
_reset();
if(K3==0)
delay();
if(K3==0)
num=3;
B0=1;
P2=0xfe;
P0=Tab[num];
while(!K3);
_reset();
if(K4==0)
delay();
if(K4==0)
num=4;
B0=1;
P2=0xfe;
P0=Tab[num];
while(!K4);
_reset();
if(K5==0)
delay();
if(K5==0)
num=5;
B0=1;
P2=0xfe;
P0=Tab[num];
while(!K5);
_reset();
if(K6==0)
delay();
if(K6==0)
num=6;
B0=1;
P2=0xfe;
P0=Tab[num];
while(!K6);
_reset();
if(K7==0)
delay();
if(K7==0)
num=7;
B0=1;
P2=0xfe;
P0=Tab[num];
while(!K7);
_reset();
if(K8==0)
delay();
if(K8==0)
num=8;
B0=1;
P2=0xfe;
P0=Tab[num];
while(!K8);
_reset();
void main(void)
num=0;
TMOD=0x01;
TH0=(65536-46083)/256;
TL0=(65536-46083)%256;
EA=1;
ET0=1;
TR0=1;
int_time=0;
second=0;
key();
if(flag1){flag1=0;break;}
void interserve(void)interrupt 1 using 1
TR0=0;
int_time++;
if(int_time==20)
int_time=0;
second++;
if(second==N)
EA=0;
ET0=0;
TR0=0;
_reset();
return;
TR0=1;
(38.21 KB, 下载次数: 53)
下载附件
2020-12-17 21:58 上传
连接图
