标题: 单片机抢答器程序和仿真 [打印本页]
作者: 奔跑步    时间: 2021-3-14 14:49
标题: 单片机抢答器程序和仿真
#include <reg52.h>          //定义头文件
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x84};
uchar code table0[]={0xf7,0xfe,0xfd,0xfb};                                         //数码管数组
unsigned char code table2[]={0xef,0xdf,0xbf,0x7f};
uchar display[]={0,0,0,0};              //数码管的初始值
void sw1();
void sw2();
void sw3();                         //定义初始化
void sw4();
void xianshi();
void init();
uchar temp,num2,x,x1,x2,a,count;
int num,num1;
uchar key;
uchar i,j;
sbit k1=P1^0;                           //定义引脚
sbit k2=P1^1;
sbit k3=P1^2;
sbit k4=P1^3;
sbit sp=P1^4;
sbit l1=P1^5;
sbit l2=P1^6;
sbit P3_4=P3^4;
sbit P3_5=P3^5;
sbit P3_6=P3^6;
sbit P3_7=P3^7;
void delay(uchar z)
uchar x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void init()
  a=0;
  TMOD=0x01;
  TH0=(65536-10000)/256;
  TL0=(65536-10000)%256;
  EA=1;
  ET0=1;
  if(k1==0)
     delay(5);
      if(k1==0)
    num++;
    if(num==99)
    num=0;
   num2=num;
   while(k1==0);
   if(k2==0)
     delay(5);
      if(k2==0)
       num--;
     if(num==-1)
      num=99;
     num2=num;
    while(k2==0);
      if(k3==0)
              delay(5);
                     if(k3==0)
               x++;
                if(x==2)
                   x=0;
                 while(k3==0);
           void keyboad()
                    P3=0xff;
                    P3_4=0;
                   temp=P3;
                  temp=temp & 0x0f;
              if (temp!=0x0f)
                   delay(5);
             temp=P3;
                 temp=temp & 0x0f;
                      if (temp!=0x0f)
                  temp=P3;
                  temp=temp & 0x0f;
         switch(temp)                                //swith语句扫描按键
   case 0x0e:
   {delay(5);num1=4;l2=0;xianshi();} break;
   case 0x0d:
   {delay(5);num1=3;l2=0;xianshi();}break;
   case 0x0b:
   {delay(5);num1=2;l2=0;xianshi();}break;
   case 0x07:
   {delay(5);num1=1;l2=0;xianshi();} break;
         P3=0xff;
             P3_5=0;
           temp=P3;
             temp=temp & 0x0f;
                   if (temp!=0x0f)
           delay(5);
          temp=P3;
              temp=temp & 0x0f;
                    if (temp!=0x0f)
                temp=P3;
                   temp=temp & 0x0f;
                 case 0x0e:
                 {delay(5);num1=8;l2=0;xianshi();} break;
                 case 0x0d:
                 {delay(5);num1=7;l2=0;xianshi();} break;
                 case 0x0b:
                 {delay(5);num1=6;l2=0;xianshi();} break;
                 case 0x07:
                 {delay(5);num1=5;l2=0;xianshi();} break;
       P3=0xff;
            P3_6=0;
       temp=P3;
           temp=temp & 0x0f;
         if (temp!=0x0f)
              delay(5);
         temp=P3;
        temp=temp & 0x0f;
          if (temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
case 0x0e:
{delay(5);num1=12;l2=0;xianshi();} break;
case 0x0d:
{delay(5);num1=11;l2=0;xianshi();} break;
case 0x0b:
{delay(5);num1=10;l2=0;xianshi();} break;
case 0x07:
{delay(5);num1=9;l2=0;xianshi();} break;
P3=0xff;
P3_7=0;
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
delay(5);
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
case 0x0e:
{delay(5);num1=16;l2=0;xianshi();} break;
case 0x0d:
{delay(5);num1=15;l2=0;xianshi();} break;
case 0x0b:
{delay(5);num1=14;l2=0;xianshi();} break;
case 0x07:
{delay(5);num1=13;l2=0;xianshi();} break;
temp=P3;
P0=table[key];
void xianshi()
TR0=0;
num=0;
sp=1;
delay(100);
sp=0;
for(a=0;a<4;a++)
delay(5);
P2=table0[a];
P0=table[display[a]];
display[0]=num/10;
display[1]=num%10;
display[2]=num1/10;
display[3]=num1%10;
if(k4==0)
num=num2;
num1=0;
TR0=1;
l1=1;
l2=1;
return;
l1=1;
  l2=1;
  sp=0; //生成脉冲
  x=0;
   num=num2=30;
    if(x==1)
   delay(5);
   TR0=1;
    keyboad();
    if(k4==0)
     l1=1;
    l2=1;
    delay(5);
   num=num2;
   TR0=1;
for(a=0;a<4;a++)
delay(5);
P2=table0[a];
display[0]=num/10;
display[1]=num%10;
display[2]=num1/10;
display[3]=num1%10;
init();
/********定时器0********/
void time0() interrupt 1
count++;
if(k4==0)
num=num2;
TR0=1;
num1=0;
return;
for(a=0;a<4;a++)
delay(10);
P2=table0[a];
display[0]=num/10;
display[1]=num%10;
display[2]=num1/10;
display[3]=num1%10;
if(count==100)
count=0;
num--;
if(num<5)
l1=~l1;
sp=1;
delay(200);
sp=0;
if(num==0)
l1=0;
sp=1;delay(200);sp=0;
delay(100);
delay(100);
if(num==0)
xianshi();
if(k4==0)
l1=1;
l2=1;
num=num2;
TR0=1;
return;
x2++;
if(x2==4)
x2=0;
P3=table2[x2]; }
