求助:avr编程 WinAVR程序移植到iar for avr 出现错误
by64214
2021-3-21 11:46
出现错误
WinAVR
pgmspace.h
头文件
函数
[url=]表情[/url]
#definepgm_read_byte(address_short) pgm_read_byte_near(address_short)
iar for avr
pgmspace.h
头文件
函数 没有
pgm_read_byte
函数
/* PGM_P points into program address space */ PGM_P指向程序地址空间
#ifdef __HAS_ELPM__
#define PGM_P const char __farflash *
#define PGM_VOID_P const void __farflash *
#else
#define PGM_P const char __flash *
#define PGM_VOID_P const void __flash *
#endif /* __HAS_ELPM__ */
#define __PRINTFPR_P _Pragma("__printf_args") \
_Pragma("library_default_requirements _formatted_write_P = unknown")
#define __SCANFPR_P _Pragma("__scanf_args") \
_Pragma("library_default_requirements _formatted_read_P = unknown")
/* Language extensions are necessary to cope with multiple address spaces */
必须使用语言扩展才能应对多个地址空间
#pragma language=save
#pragma language=extended
__PRINTFPR_P int printf_P(PGM_P __format,...);
__SCANFPR_P int scanf_P(PGM_P __format,...);
__PRINTFPR_P int sprintf_P(char *__s,PGM_P __format,...);
__SCANFPR_P int sscanf_P(const char *__s, PGM_P __format,...);
int puts_P(PGM_P __s);
PGM_P strerror_P(int errnum);
size_t strlen_P(PGM_P s);
__x_z int memcmp_P(const void *, PGM_VOID_P, size_t);
__x_z void *memcpy_P(void *, PGM_VOID_P, size_t);
__x_z char *strcat_P(char *, PGM_P);
__x_z int strcmp_P(const char *, PGM_P);
__x_z char *strcpy_P(char *, PGM_P);
__x_z char *strncat_P(char *, PGM_P, size_t);
__x_z int strncmp_P(const char *, PGM_P, size_t);
__x_z char *strncpy_P(char *, PGM_P, size_t);
__x_z int memcmp_G(const void *, const void __generic *, size_t);
__x_z void *memcpy_G(void *, const void __generic *, size_t);
__x_z char *strcat_G(char *, const char __generic *);
__x_z int strcmp_G(const char *, const char __generic *);
__x_z char *strcpy_G(char *, const char __generic *);
__z size_t strlen_G(const char __generic *);
__x_z char *strncat_G(char *, const char __generic *, size_t);
__x_z int strncmp_G(const char *, const char __generic *, size_t);
__x_z char *strncpy_G(char *, const char __generic *, size_t);
int puts_G(const char __generic *);
现在
WinAVR程序
移植到iar for avr
pgm_read_byte 出现错误 请求指导 下面程序程序 应该怎么改?
void Common_Show(INT8U P,INT8U L,INT8U W,char *r)
INT8U i;
//显示在左半屏或左右半屏
if(L < 64)
CS1_1(); CS2_0();
LCD_Write_Command(LCD_PAGE+P);
LCD_Write_Command(LCD_COL+L);
//全部显示在左半屏
if(L + W < 64)
for(i=0; i<W; i++) LCD_Write_Data(<b>pgm_read_byte</b>(r+i));
//如果越界则跨越左右半屏显示
//左半屏显示
for(i=0; i<64-L; i++) LCD_Write_Data(<b>pgm_read_byte</b>(r+i));
//右半屏显示
CS1_0(); CS2_1();
LCD_Write_Command(LCD_COL);
for(i=64-L; i<W; i++) LCD_Write_Data(<b>pgm_read_byte</b>(r+i));
//全部显示在右半屏
CS1_0(); CS2_1();
LCD_Write_Command(LCD_COL+L-64);
KongQuan
2021-3-21 13:23
试试自己定义替换
#definepgm_read_byte(address_short) *(const char __flash * ( address_short))
by64214
2021-3-21 14:59
谢谢指导!
#define pgm_read_byte(address_short) *(const char __flash * ( address_short))
编译 出现 Error[Pe018]: expected a ")" Error[Pe029]: expected an expression
