标题: 蓝牙或者串口控制舵机程序 [打印本页]
作者: zzz666zzzz 时间: 2021-3-24 15:58
标题: 蓝牙或者串口控制舵机程序
51单片机,蓝牙控制舵机程序
#include<AT89x52.H>
#include <intrins.h>
unsigned char count; //0.5ms次数标识
sbit pwm =P0^4; //PWM信号输出
uchar count = 0;
uchar scount = 15;
void delay(unsigned char i)//延时
unsigned char j,k;
for(j=i;j>0;j--)
for(k=125;k>0;k--);
void init()
SCON=0x50;
TMOD|=0x20;
TH1=0xfd;
TL1=0xfd;
TCON|=0x40;
TR1=1;
ES = 1;
EA=1;
void Time0_Init() //定时器初始化
TMOD|= 0x01; //定时器0工作在方式1
IE|= 0x82;
TH0 = 0xff;
TL0 = 0x9c; //11.0592MZ晶振
TR0=1; //定时器开始
/* 定时器0中断服务程序 */
void Time0() interrupt 1
TH0= 0xff; //重装初值0.1ms
TL0= 0x9c;
if(count <= scount) //控制占空比左右
//如果count的计数小于(5-25)也就是0.5ms-2.5ms则这段小t周期持续高电平。产生方波
pwm = 1;
pwm = 0;
count=(count+1); //0.5ms次数加1
count=count%200; //次数始终保持为40 即保持周期为20ms
count=0;
Time0_Init();
init();
//串口中断
void time() interrupt 4
unsigned char receiveData;
receiveData=SBUF;//出去接收到的数据
RI = 0;//清除接收中断标志位
SBUF=receiveData;//将接收到的数据放入到发送寄存器
while(!TI); //等待发送数据完成
TI=0;
switch(SBUF)
case '1':scount--;
if(scount <= 5)
scount = 5;
count = 0;
break;
case '2':scount++;
if(scount >= 25)
scount = 25;
count = 0;
break;
case '3':scount--;
if(scount<= 10)
scount = 10;
count = 0;break;
case '4':scount++;
if(scount >= 20)
scount = 20;
count = 0;
break;
Powered by Discuz! X3.1 |
