标题: 这2个单片机程序为什么不能通讯,求帮助,谢谢大家 [打印本页]
作者: pet    时间: 2021-3-25 11:42
主机
#include<reg52.h>
#include<stdio.h>
#include "delay.h"
#include "math.h"
#define TRUE 0x01
#define FALSE 0x00
sbit Echo=P2^0;
sbit Trip=P2^1;
char dis0[16];
unsigned long time_20ms;
unsigned char DisFlag=FALSE;
float JuLi;
long JlCoun=0;
void TIM2Inital(void);
void uartSendStr(unsigned char *s,unsigned char length);
void UART_Init(void);
void uartSendByte(unsigned char dat);
void main (void)
        TMOD|=0x01;
        TH0=0;
        TL0=0;
        ET0=1;
        EA=1;
        UART_Init();
        sprintf(dis0,"*%05d#",(unsigned int)JuLi);
        uartSendStr(dis0,7);
        while (1)
                Trip=1;
                DelayUs2x(4);
                Trip=0;
                while(!Echo);
                TR0=1;
                JuLi=(float)(JlCoun*17)/100.0*1.08;
                if((JlCoun>0)&&(JuLi>0))
                DelayMs(200);
                DelayMs(200);
    SCON  = 0x50;
    TMOD |= 0x20;
    TH1   = 0xFD;
        TL1 = TH1;
    TR1   = 1;
    EA    = 1;
    ES    = 1;
        unsigned char time_out;
        time_out=0x00;
        SBUF = dat;
        while((!TI)&&(time_out<100))
        {time_out++;DelayUs2x(10);}
        TI = 0;
        unsigned char NUM;
        NUM=0x00;
        while(NUM<length)
                uartSendByte(*s);
                s++;
                NUM++;
void UART_SER (void) interrupt 4
        if(RI)
                RI=0;
        if(TI)
        TI=0;
从机
#include <reg52.h>
#include"delay.h"
#include "1602.h"
#include <stdio.h>
sbit shuibegn =P1^3;
sbit buzzer =P1^2;
unsigned long times_20ms=0;
unsigned char firstin =0;
unsigned char tab[8];
unsigned char Count=0;
unsigned char  uartbusy =0;
unsigned char reportFlag = 0;
unsigned char dis1[16];
unsigned char i;
unsigned int juLi=12345;
unsigned char laterNum =0;
void Init_Timer0(void);
void SendByte(unsigned char dat);
void SendStr(unsigned char *s,unsigned char length);
void main (void)
        Init_Timer0();
        UART_Init();
        LCD_Init();
        DelayMs(20);
        LCD_Clear();
        LCD_Write_String(0,0,"My Designer! ");
        sprintf(dis1,"Now:%05dmm ",juLi);
        LCD_Write_String(0,1,dis1);
                 if ( juLi>10&&juLi<20)
                 {buzzer=~buzzer;
                DelayMs(10); }
                DelayMs(200);
        TMOD |= 0x01;
        TH0=(65536-20000)/256;
        TL0=(65536-20000)%256;
        EA=1;
        ET0=1;
        TR0=1;
    SCON  = 0x50;
    TMOD |= 0x20;
    TH1   = 0xFD;
          TL1 = TH1;
    TR1   = 1;
    EA    = 1;
    ES    = 1;
        time_out=0x00;
        SBUF = dat;
        TI = 0;
        unsigned char NUM;
        NUM=0x00;
        while(NUM<length)
                SendByte(*s);
                s++;
                NUM++;
void Timer0_isr(void) interrupt 1
        times_20ms++;
        if(laterNum>0)
        {laterNum--;}
        {juLi = 0;}
        if(uartbusy>0)
        {uartbusy--;}
                firstin =0;
                Count=0;
        unsigned char r_buf;
        if(RI)
                RI=0;
                r_buf = SBUF;
                uartbusy = 20;
                if(r_buf=='*')
                        firstin = 1;
                        Count = 0;
                        tab[Count++]=r_buf;
                else if(firstin == 1)
                        tab[Count++]=r_buf;
                        if(Count>=7)
                                if(tab[6]=='#')
                                        juLi = (tab[1]-'0')*10000+        (tab[2]-'0')*1000+(tab[3]-'0')*100+(tab[4]-'0')*10+(tab[5]-'0');
                                        laterNum = 150;
                                firstin =0;
                                Count=0;
        if(TI)
        TI=0;
以上怎么通讯不了,求大神请教
作者: 51hei团团    时间: 2021-3-25 16:37
检查一下电路看看,gnd接上了没有?有没有短路
作者: pet    时间: 2021-3-25 17:02
gnd接上了的,还是通讯不了
