标题: 键盘专用芯片MM74c922的Proteus仿真程序 [打印本页]
作者: taotie    时间: 2021-4-1 10:34
演示程序:
#include <avr/io.h>
#include <util/delay.h>
#define  INT8U   unsigned  char
#define  INT16U   unsigned  int
//蜂鸣器
#define  beep( ) PORTD^= _BV(PD7)
//按键判断有键按下时74922AD向pa7发送高电平
#define  key_pressed ((PINA & 0x80) == 0x80)
//获取按键
#define  key_no (PINA & 0x0f)
//数码管段码
const INT8U  SEG_CODE  [ ] =
0X3F,0X06,0X5B,0X4F,0X66,0X6D,0X7D,0X07,
0X7F,0X6F,0X77,0X7C,0X39,0X5E,0X79,0X71
//发声子程序
void sounder( )
INT8U    i ;
for (i=0 ; i<100 ; i++)
_delay_us(190); beep( );
int main()
   DDRA =0X00; PORTA=0XFF;
DDRC=0XFF; PORTC=0X00;
DDRD=0XFF; PORTD=0XFF;
   while (1)
if  ( key_pressed )     //有键按下
PORTC = SEG_CODE[key_no];
sounder( );
