为什么在Keil里总是出现error C129: missing ';' before 'char'
dpjzzq
2021-4-2 19:57
#include<reg51.h>
#define uchar designed char
#define uint designed int
void delay(uintm);
uchar code led1[6]={0x00;0xfe;0xbd;0xdb;0xef;0x00} ;
main()
{uchar i;
{for(i=0;i<6;i++)
P1=led1[i];
delay(200)
void delay (uint m);
unsigned int a,b;
for (c=m;c>0;c--)
for (b=142;b>0;b--)
for (a=2;a>0;a--);
张天师
2021-4-2 22:17
designed char和designed int是什么鬼。修饰词错误,应该是unsigned char/unsigned int
wulin
2021-4-3 08:39
楼主太粗心,就这几行代码抄写错误一堆。
#include<reg51.h>
void delay(uint m);
uchar code led1[6]={0x00,0x7e,0xbd,0xdb,0xe7,0xff};
main()
uchar i;
for(i=0;i<6;i++)
P1=led1[i];
delay(200);
void delay (uint m)
unsigned int a,b,c;
for (c=m;c>0;c--)
for (b=142;b>0;b--)
for (a=2;a>0;a--);
dpjzzq
2021-4-3 13:06
谢谢,谢谢,我真的太粗心了
