AS608 FPM10A指纹模块的单片机驱动程序
枕头君。
2021-4-3 20:40
电容式指纹模块的上位机调试以及程序 比as608更简小 更方便
(336.25 KB, 下载次数: 57)
下载附件
2021-4-3 20:40 上传
#include<reg52.h>
#include<intrins.h>
#include"buzz.h"
#include"key.h"
#include"uart.h"
#include"delay.h"
#include"FPM10A.h"
#include"lcd_1602.h"
LCD1602_Init(); //初始化液晶
LCD1602_Display(0x80,"Fingerprint Test",0,16); //液晶开机显示界面
Uart_Init(); //初始化串口
Key_Init(); //初始化按键
Delay_Ms(200); //延时500MS,等待指纹模块复位
Device_Check(); //校对指纹模块是否接入正确,液晶做出相应的提示
Delay_Ms(1000); //对接成功界面停留一定时间
/**************进入主功能界面****************/
LCD1602_Display(0x80," search finger ",0,16); //第一排显示搜索指纹
LCD1602_Display(0xc0," Add delete",0,16); //添加和删除指纹
if(local_date==0)
LCD1602_Display(0x80, " *",0,2);
LCD1602_Display(0xc0, " ",0,2);
LCD1602_Display(0xc0+8," ",0,2);
else if(local_date==1)
LCD1602_Display(0x80, " ",0,2);
LCD1602_Display(0xc0, " *",0,2);
else if(local_date==2)
LCD1602_Display(0xc0+8," *",0,2);
//确认键
if(KEY_OK == 0)
while(KEY_OK == 0);//等待松开按键
switch(local_date)
case 0: //搜索指纹
FPM10A_Find_Fingerprint();
break;
case 1: //添加指纹
FPM10A_Add_Fingerprint();
break;
case 2: //清空指纹
FPM10A_Delete_All_Fingerprint();
break;
//切换键
if(KEY_DOWN == 0)
while(KEY_DOWN == 0); //等待松开按键
if(local_date<=2)
local_date++;
if(local_date==3)
local_date=0;
Delay_Ms(100); //延时判断100MS检测一次
所有代码51hei提供下载:
1.程序((程序兼容AS608 FPM10A)).rar
(114.97 KB, 下载次数: 25)
2021-4-3 20:39 上传
点击文件名下载附件
下载积分: 黑币 -5
