标题: SL1586 30V 1.2A 1.4MHz PWM SYN降压调节器 [打印本页]
作者: 森利威尔电子    时间: 2021-4-28 11:21
General Description   The SL1586 is a high frequency, synchronous, rectified, step-down, switch-mode converter with internal powerMOSFETs. It offers a very compact solution to achieve a 1.5A peak output current over a wide input supply range,with excellent load and line regulation.The SL1586 requires a minimal number of readily available, external components and is available in a space savingSOT23-6 package.
Features
• Wide 4V to 30V Operating Input Range
  • 1.2A Continuous Output Current
  • 1.4MHz Switching Frequency
  • Short Protection with Hiccup-Mode
  • Built-in Over Current Limit
  • Built-in Over Voltage Protection
  • Force-PWM Mode
  • Internal Soft-Start
  • 200mΩ/150mΩ Low RDS(ON) Internal PowerMOSFETs
  • Output Adjustable from 0.8V
  • No Schottky Diode Required
  • Integrated internal compensation
  • Thermal Shutdown
  • Available in SOT23-6 Package
  • -40°C to +85°C Temperature Range
Applications
• CCTV Camera
  • Flat-Panel Television and Monitor
  • Battery Charger
  • Distributed Power Systems
Typical Application Circuit
Typical Performance Characteristics (5) (6)
Note (5): Performance waveforms are tested on the evaluation board.
Note (6): VIN =12V, VOUT=3.3V, TA = +25oC, unless otherwise noted.
