标题: STM32F103单片机输出两路不同频率的正弦波源程序 [打印本页]
作者: gxs2890901427    时间: 2021-5-8 01:39
STM32单片机的DAC不支持直接生成正弦波,需要用读表法生成正弦波,外加DMA传输,生成正弦波。代码如下:
完整工程在附件。
  1. #include "sign.h"
  2. u16 SineWave1_Value[256];
  3. u16 SineWave2_Value[256];
  4. /********正弦波输出表***********/
  5. //cycle        :波形表的位数        (0~256)
  6. //Um                :输出电压的峰值(0~1.5)
  7. /*******************************/
  8. void SineWave1_Data( u16 cycle ,u16 *D,float Um)
  9. {
  10.     u16 i;
  11.     for( i=0;i<cycle;i++)
  12.     {
  13.         D[i]=(u16)((Um*sin(( 1.0*i/(cycle-1))*2*PI)+Um)*4095/3.3);
  14.     }
  15. }
  16. void SineWave2_Data( u16 cycle ,u16 *D,float Um)
  17. {
  18.     u16 i;
  19.     for( i=0;i<cycle;i++)
  20.     {
  21.         D[i]=(u16)((Um*sin(( 1.0*i/(cycle-1))*2*PI)+Um)*4095/3.3);
  22.     }
  23. }
  24. /****************初始化引脚******************/
  25. void SineWave_GPIO_Config(void)
  26. {
  27.     GPIO_InitTypeDef GPIO_InitStructure;
  28.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);  //开时钟
  29.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;       //推挽输出模式
  30.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;   //输出速率
  31.     GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_4|GPIO_Pin_5 ; //选择引脚
  32.     GPIO_SetBits(GPIOA,GPIO_Pin_4)  ;   //拉高输出
  33.           GPIO_SetBits(GPIOA,GPIO_Pin_5)  ;   //拉高输出
  34.     GPIO_Init(GPIOA, &GPIO_InitStructure);      //初始化
  35. }
  36. /******************DAC初始化ˉ*************************/
  37. void SineWave_DAC_Config( void)
  38. {
  39.         DAC_InitTypeDef DAC_InitStructure;
  40.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);//初始化DAC的时钟
  41.         DAC_StructInit(&DAC_InitStructure);
  42.         DAC_InitStructure.DAC_Trigger = DAC_Trigger_T2_TRGO;//指定DAC1的触发定时器TIM2
  43.         DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;//无波形产生
  44.         DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable; //不是能DAC输出缓冲
  45.         DAC_Init(DAC_Channel_1, &DAC_InitStructure);//初始化DAC channel1
  46.         DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;//指定DAC2的触发定时器TIM6
  47.         DAC_Init(DAC_Channel_2, &DAC_InitStructure);//初始化DAC channel2
  48.         DAC_Cmd(DAC_Channel_1, ENABLE); //使能DAC channel1
  49.         DAC_Cmd(DAC_Channel_2, ENABLE); //使能DAC channel2
  50.         DAC_DMACmd(DAC_Channel_1, ENABLE); //使能DAC Channel1的DMA
  51.         DAC_DMACmd(DAC_Channel_2, ENABLE); //使能DAC Channel2的DMA
  52.
  53. }
  54. /*********定时器初始化************/
  55. void SineWave_TIM_Config(u32 Wave1_Fre,u32 Wave2_Fre)
  56. {
  57.    TIM_TimeBaseInitTypeDef    TIM_TimeBaseStructure;
  58.    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2|RCC_APB1Periph_TIM6, ENABLE);//开时钟
  59.    TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  60.    TIM_TimeBaseStructure.TIM_Period = Wave1_Fre; //正弦波1频率设置
  61.    TIM_TimeBaseStructure.TIM_Prescaler = 0x0; //没有预分频
  62.    TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; //时钟不分频
  63.    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//增计数
  64.    TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  65.    TIM_TimeBaseStructure.TIM_Period = Wave2_Fre; //正弦波2频率设置
  66.    TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);
  67.    TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);//更新TIM2输出触发
  68.    TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update);//更新TIM6输出触发
  69. }
  70. /*********DMA配置***********/
  71. void SineWave_DMA_Config(void)
  72. {
  73.         DMA_InitTypeDef DMA_InitStructure;
  74.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);//初始化DMA2的时钟
  75.         DMA_DeInit(DMA2_Channel3); //将DMA配置成默认值
  76.         DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12R1;//指定DMA2通道3的目标地址为DAC1_DHR12R1
  77.         DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SineWave1_Value;//指定DMA的源地址为数组Sine12bit
  78.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;//外设作为数据传输的目的地
  79.         DMA_InitStructure.DMA_BufferSize = 256;//DMA缓冲区大小
  80.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设机地址存器不变
  81.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增
  82.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//外设数据宽度为半字
  83.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;//内存数据宽度为半字
  84.         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//工作在循环缓存模式,数据传输数为0时,自动恢复配置初值
  85.         DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;//非常高优先级
  86.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;//通道未被设置成内存到内存模式,与循环模式相对
  87.         DMA_Init(DMA2_Channel3, &DMA_InitStructure);//初始化DMA
  88.         DMA_DeInit(DMA2_Channel4);
  89.         DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12R2;//指定DMA2通道3的目标地址为DAC2_DHR12R2
  90.         DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SineWave2_Value;//指定DMA的源地址为数组Sine12bit
  91.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;//外设作为数据传输的目的地
  92.         DMA_InitStructure.DMA_BufferSize = 256;//DMA缓冲区大小
  93.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设机地址存器不变
  94.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增
  95.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//外设数据宽度为半字
  96.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;//内存数据宽度为半字
  97.         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//工作在循环缓存模式,数据传输数为0时,自动恢复配置初值
  98.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;//通道未被设置成? 诖娴侥诖婺J剑胙纺J较喽?
  99.         DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  100.         DMA_Init(DMA2_Channel4, &DMA_InitStructure);
  101.         DMA_Cmd(DMA2_Channel3, ENABLE); //使能DMA的channel3
  102.         DMA_Cmd(DMA2_Channel4, ENABLE); //使能DMA的channel4
  103.
  104.
  105. }
  106. /**********正弦波初始化**********************/
  107. //Wave1_Fre:        频率值(0~60 000)Hz
  108. //Um                         :        电压峰值(0.0~1.5)V
  109. /*******************************************/
  110. void SineWave_Init(u16 Wave1_Fre,u16 Wave2_Fre,float Um)
  111. {
  112.         u32 f1,f2;
  113.         f1=(u32)(72000000/sizeof(SineWave1_Value)*2/Wave1_Fre);//计算频率
  114.         f2=(u32)(72000000/sizeof(SineWave2_Value)*2/Wave2_Fre);//计算频率
  115.         SineWave1_Data(256,SineWave1_Value,Um);     //生成输出正弦波的波形表
  116.         SineWave1_Data(256,SineWave2_Value,Um);     //生成输出正弦波的波形表
  117.         SineWave_GPIO_Config();              //初始化io
  118.         SineWave_TIM_Config(f1,f2);            //初始化定时器2
  119.         SineWave_DAC_Config();              //配置DAC
  120.         SineWave_DMA_Config();       //配置DMA
  121.         TIM_Cmd(TIM2, ENABLE);             //开启定时器
  122.         TIM_Cmd(TIM6, ENABLE);             //开启定时器
  123. }
所有代码51hei提供下载:
输出两路不同频率正弦波.7z (209.32 KB, 下载次数: 158)
作者: njlinjie    时间: 2022-1-29 00:27
不错,可以用
作者: hisun    时间: 2023-3-12 12:51
哎呀,还差点分。想下载跑下试试是不是的,我学那国民的用两个DAC出来的频率就不对只一个一个用就没问题,搞啥名堂呢。
作者: cjavip    时间: 2023-6-16 22:42
还差点分。想下载跑下试试效果
作者: cuihaodianzi    时间: 2023-10-20 17:19
好东西,先评论再下载
作者: 老愚童63    时间: 2023-10-21 16:19
输出是不是A4,A5引脚?
