CS1237驱动程序范例
again00txhj
2021-6-18 17:24
CS1237驱动程序范例
CS1237驱动范例,验证可用
#include "HT67F2390.h"
#include "my_type.h"
#include "stdlib.h"
#include "math.h"
volatile bit_flag CS1237_lib_bit_0;
volatile long ADC_OUT_DATA;
volatile unsigned char ad_loop1;
void CS1237_CLK1(void)
CS1237_SCLK1_IO=0;
CS1237_ADC_DOU1_IO=1;
GCC_NOP();GCC_NOP();GCC_NOP();GCC_NOP();GCC_NOP();
CS1237_SCLK1=1;
CS1237_SCLK1=0;
void CS1237_ADC1_PowerOff(void)
CS1237_SCLK1=1;
void CS1237_AD_Read1(void)
unsigned char i;
if(adc1_f==0)
CS1237_SCLK1_IO=0;
CS1237_SCLK1=0;
ADC_OUT_DATA=0;
while(CS1237_ADC_DOU1);
_emi=0;
for(i=0;i<24;i++)
ADC_OUT_DATA<<=1;
CS1237_CLK1();
if(CS1237_ADC_DOU1)
ADC_OUT_DATA++;
CS1237_CLK1();
CS1237_CLK1();
CS1237_CLK1();
_emi=1;
ad_loop1++;
if(ad_loop1>3)
ad_loop1=3;
adc1_f=1;
if((ADC_OUT_DATA&0x800000)!=0)
ADC_OUT_DATA+=0xff000000;
ADC_OUT_DATA=ADC_OUT_DATA+0x800000;
ado_temp=ADC_OUT_DATA;
ado_temp>>=weight_adc_enob;
