普通的交通灯
blue-16
2021-7-5 23:27
普通的交通灯
#include <reg52.h>
sbit RED_A=P0^0;
sbit YELLOW_A=P0^1;
sbit GREEN_A=P0^2;
sbit RED_B=P0^3;
sbit YELLOW_B=P0^4;
sbit GREEN_B=P0^5;
uchar Flash_Count = 0;
Operation_Type = 1;
void DelayMS(uint x)
uchar t;
while(x--)
for(t=120;t>0;t--);
void Traffic_lignt()
switch(Operation_Type)
case 1:
RED_A=1;YELLOW_A=1;GREEN_A=0;
RED_B=0;YELLOW_B=1;GREEN_B=1;
DelayMS(2000);
Operation_Type = 2;
break;
case 2:
DelayMS(200);
YELLOW_A=~YELLOW_A;
if(++Flash_Count !=10)
return;
Flash_Count=0;
Operation_Type = 3;
break;
case 3:
RED_A=0;YELLOW_A=1;GREEN_A=1;
RED_B=1;YELLOW_B=1;GREEN_B=0;
DelayMS(2000);
Operation_Type = 4;
break;
case 4:
DelayMS(200);
YELLOW_B=~YELLOW_B;
return;
Flash_Count=0;
Operation_Type = 1;
break;
Traffic_lignt();
