if(receCount > 4)
switch(receBuf[1])
case 1://读取线圈状态(读取点 16位以内)
case 3://读取保持寄存器(一个或多个)
case 5://强制单个线圈
case 6://设置单个寄存器
if(receCount >= 8)
{//接收完成一组数据
//应该关闭接收中断
tempAddr = addr & 0xfff;
//只取低8位地址
switch(tempAddr & 0xff)
case 0:
break;
case 1:
*tempData = testCoil;
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 9:
break;
case 10:
break;
case 11:
break;
case 12:
break;
case 13:
break;
case 14:
break;
case 15:
break;
case 16:
break;
default:
break;
case 0:
break;
case 1:
testCoil = tempData;
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 9:
break;
case 10:
break;
case 11:
break;
case 12:
break;
case 13:
break;
case 14:
break;
case 15:
break;
case 16:
break;
default:
break;
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 9:
break;
case 10:
break;
case 11:
break;
case 12:
break;
case 13:
break;
case 14:
break;
case 15:
break;
case 16:
*tempData = testRegister;
break;
default:
break;
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 9:
break;
case 10:
break;
case 11:
break;
case 12:
break;
case 13:
break;
case 14:
break;
case 15:
break;
case 16:
testRegister = tempData;
break;
default:
break;
