// This list should be filled with Application specific Cluster IDs.
const cId_t GenericApp_ClusterList[GENERICAPP_MAX_CLUSTERS] =
GENERICAPP_CLUSTERID
byte GenericApp_TaskID; // Task ID for internal task/event processing
// This variable will be received when
// GenericApp_Init() is called.
devStates_t GenericApp_NwkState;
byte GenericApp_TransID; // This is the unique message ID (counter)
void Delay_MS(unsigned int msec);
void UartSendString(char *Data, int len);
void Delay10us(void);
__interrupt void UART0_ISR(void);
* @fn GenericApp_Init
* @brief Initialization function for the Generic App Task.
* This is called during initialization and should contain
* any application specific initialization (ie. hardware
* initialization/setup, table initialization, power up
* notificaiton ... ).
* @param task_id - the ID assigned by OSAL. This ID should be
* used to send messages and set timers.
* @return none
void GenericApp_Init( uint8 task_id )
GenericApp_TaskID = task_id;
GenericApp_NwkState = DEV_INIT;
GenericApp_TransID = 0;
* @fn GenericApp_ProcessEvent
* @brief Generic Application Task event processor. This function
* is called to process all events for the task. Events
* include timers, messages and any other user defined events.
* @param task_id - The OSAL assigned task ID.
* @param events - events to process. This is a bit map and can
* contain more than one event.
* @return none
uint16 GenericApp_ProcessEvent( uint8 task_id, uint16 events )
afIncomingMSGPacket_t *MSGpkt;
afDataConfirm_t *afDataConfirm;
// Data Confirmation message fields
byte sentEP;
ZStatus_t sentStatus;
byte sentTransID; // This should match the value sent
(void)task_id; // Intentionally unreferenced parameter
if ( events & SYS_EVENT_MSG )
MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( GenericApp_TaskID );
while ( MSGpkt )
switch ( MSGpkt->hdr.event )
case ZDO_CB_MSG:
GenericApp_ProcessZDOMsgs( (zdoIncomingMsg_t *)MSGpkt );
break;
case KEY_CHANGE:
GenericApp_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
break;
case AF_DATA_CONFIRM_CMD:
// This message is received as a confirmation of a data packet sent.
// The status is of ZStatus_t type [defined in ZComDef.h]
// The message fields are defined in AF.h
afDataConfirm = (afDataConfirm_t *)MSGpkt;
sentEP = afDataConfirm->endpoint;
sentStatus = afDataConfirm->hdr.status;
sentTransID = afDataConfirm->transID;
(void)sentEP;
(void)sentTransID;
// Action taken when confirmation is received.
if ( sentStatus != ZSuccess )
// The data wasn't delivered -- Do something
break;
case AF_INCOMING_MSG_CMD:
GenericApp_MessageMSGCB( MSGpkt );
break;
case ZDO_STATE_CHANGE:
GenericApp_NwkState = (devStates_t)(MSGpkt->hdr.status);
if ( (GenericApp_NwkState == DEV_ZB_COORD)
|| (GenericApp_NwkState == DEV_ROUTER)
|| (GenericApp_NwkState == DEV_END_DEVICE) )
break;
default:
break;
// Release the memory
osal_msg_deallocate( (uint8 *)MSGpkt );
// Next
static void GenericApp_ProcessZDOMsgs( zdoIncomingMsg_t *inMsg )
switch ( inMsg->clusterID )
case End_Device_Bind_rsp:
if ( ZDO_ParseBindRsp( inMsg ) == ZSuccess )
// Light LED
HalLedSet( HAL_LED_4, HAL_LED_MODE_ON );
#if defined( BLINK_LEDS )
// Flash LED to show failure
HalLedSet ( HAL_LED_4, HAL_LED_MODE_FLASH );
#endif
break;
case Match_Desc_rsp:
ZDO_ActiveEndpointRsp_t *pRsp = ZDO_ParseEPListRsp( inMsg );
if ( pRsp )
if ( pRsp->status == ZSuccess && pRsp->cnt )
GenericApp_DstAddr.addrMode = (afAddrMode_t)Addr16Bit;
GenericApp_DstAddr.addr.shortAddr = pRsp->nwkAddr;
// Take the first endpoint, Can be changed to search through endpoints
GenericApp_DstAddr.endPoint = pRsp->epList[0];
* @fn GenericApp_HandleKeys
* @brief Handles all key events for this device.
* @param shift - true if in shift/alt.
* @param keys - bit field for key events. Valid entries:
* HAL_KEY_SW_4
* HAL_KEY_SW_3
* HAL_KEY_SW_2
* HAL_KEY_SW_1
* @return none
static void GenericApp_HandleKeys( uint8 shift, uint8 keys )
if ( keys & HAL_KEY_SW_1 )
if ( keys & HAL_KEY_SW_2 )
if ( keys & HAL_KEY_SW_3 )
if ( keys & HAL_KEY_SW_4 )
* LOCAL FUNCTIONS
* @fn GenericApp_MessageMSGCB
* @brief Data message processor callback. This function processes
* any incoming data - probably from other devices. So, based
* on cluster ID, perform the intended action.
* @param none
* @return none
// This is the Endpoint/Interface description. It is defined here, but
// filled-in in GenericApp_Init(). Another way to go would be to fill
// in the structure here and make it a "const" (in code space). The
// way it's defined in this sample app it is define in RAM.
endPointDesc_t GenericApp_epDesc;
* LOCAL VARIABLES
* @return none
// Device hardware initialization can be added here or in main() (Zmain.c).
// If the hardware is application specific - add it here.
// If the hardware is other parts of the device add it in main().
* @return none
byte sentEP;
while ( MSGpkt )
case ZDO_CB_MSG:
break;
case KEY_CHANGE:
break;
(void)sentEP;
(void)sentTransID;
break;
break;
P1_2 = 0;
// Start sending "the" message in a regular interval.
osal_start_timerEx( GenericApp_TaskID,
GENERICAPP_SEND_MSG_EVT,
GENERICAPP_SEND_MSG_TIMEOUT );
break;
default:
break;
// Next
// Send a message out - This event is generated by a timer
// (setup in GenericApp_Init()).
if ( events & GENERICAPP_SEND_MSG_EVT )
//你只要在这里填写上,你想调用的函数,这个函数就会被周期性执行
// Send "the" message
GenericApp_Send_pm25_Message();
// Setup to send message again
* @fn GenericApp_ProcessZDOMsgs()
* @brief Process response messages
* @param none
* @return none
// Light LED
#endif
break;
if ( pRsp )
