标题: 3路循迹STM32参考代码 [打印本页]
作者: garrettzls    时间: 2021-11-6 14:03
标题: 3路循迹STM32参考代码
发出来供大家参考学习 附循迹代码
  1. //连接方式 :请参考interface.h文件
  2. //部份源码来源网络
  3. #include "stm32f10x.h"
  4. #include "interface.h"
  5. #include "LCD1602.h"
  6. #include "IRCtrol.h"
  7. #include "motor.h"
  8. #include "uart.h"
  9. //全局变量定义
  10. unsigned int speed_count=0;//占空比计数器 50次一周期
  11. char front_left_speed_duty=SPEED_DUTY;
  12. char front_right_speed_duty=SPEED_DUTY;
  13. char behind_left_speed_duty=SPEED_DUTY;
  14. char behind_right_speed_duty=SPEED_DUTY;
  15. unsigned char tick_5ms = 0;//5ms计数器,作为主函数的基本周期
  16. unsigned char tick_1ms = 0;//1ms计数器,作为电机的基本计数器
  17. unsigned char tick_200ms = 0;//刷新显示
  18. char ctrl_comm = COMM_STOP;//控制指令
  19. char ctrl_comm_last = COMM_STOP;//上一次的指令
  20. unsigned char continue_time=0;
  21. unsigned char bt_rec_flag=0;//蓝牙控制标志位
  22. //循迹,通过判断三个光电对管的状态来控制小车运动
  23. void SearchRun(void)
  24. {
  25.         //三路都检测到
  26.         if(SEARCH_M_IO == BLACK_AREA && SEARCH_L_IO == BLACK_AREA && SEARCH_R_IO == BLACK_AREA)
  27.         {
  28.                 ctrl_comm = COMM_UP;
  29.                 return;
  30.         }
  31.
  32.         if(SEARCH_R_IO == BLACK_AREA)//右
  33.         {
  34.                 ctrl_comm = COMM_RIGHT;
  35.         }
  36.         else if(SEARCH_L_IO == BLACK_AREA)//左
  37.         {
  38.                 ctrl_comm = COMM_LEFT;
  39.         }
  40.         else if(SEARCH_M_IO == BLACK_AREA)//中
  41.         {
  42.                 ctrl_comm = COMM_UP;
  43.         }
  44. }
  45. int main(void)
  46. {
  47.         delay_init();
  48.         GPIOCLKInit();
  49.         UserLEDInit();
  50.         LCD1602Init();
  51.         //IRCtrolInit();
  52.         TIM2_Init();
  53.         MotorInit();
  54.         ServoInit();
  55.
  56.         RedRayInit();
  57.         //USART3Conf(9600);
  58. while(1)
  59. {
  60.                          if(tick_5ms >= 5)
  61.                 {
  62.                         tick_5ms = 0;
  63.                         tick_200ms++;
  64.                         if(tick_200ms >= 40)
  65.                         {
  66.                                 tick_200ms = 0;
  67.                                 LEDToggle(LED_PIN);
  68.                         }
  69. //                        continue_time--;//200ms 无接收指令就停车
  70. //                        if(continue_time == 0)
  71. //                        {
  72. //                                continue_time = 1;
  73. //                                CarStop();
  74. //                        }
  75.                         //do something
  76.                         SearchRun();
  77.                         if(ctrl_comm_last != ctrl_comm)//指令发生变化
  78.                         {
  79.                                 ctrl_comm_last = ctrl_comm;
  80.                                 switch(ctrl_comm)
  81.                                 {
  82.                                         case COMM_UP:    CarGo();break;
  83.                                         case COMM_DOWN:  CarBack();break;
  84.                                         case COMM_LEFT:  CarLeft();break;
  85.                                         case COMM_RIGHT: CarRight();break;
  86.                                         case COMM_STOP:  CarStop();break;
  87.                                         default : break;
  88.                                 }
  89.                                 Delayms(10);//防抖
  90.                                 LCD1602WriteCommand(ctrl_comm);
  91.                         }
  92.                 }
  93.
  94. }
  95. }
Keil代码下载: 3路循迹STM32参考实验.7z (180.74 KB, 下载次数: 13)
