单片机16位按键控制两位数码管程序Proteus仿真
linminjy
2021-11-10 15:42
(89.46 KB, 下载次数: 25)
下载附件
2021-11-10 16:52 上传
1.尽量不要一个一个位的设置,通过P0,P1,P2设置输出状态
2.P1 = 0x0f;
delay(1);
Tmp = P1 ^ 0x0f;
P1 = 0xf0;
delay(1);
Tmp = P1 >> 4 ^ 0x0f
3.P1=0x0f->芯片内部对外输出状态
#include <reg51.h>
typedef unsigned char uint8;
typedef unsigned int uint16;
code uint8 LED_CODE1[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x3f,0x06,0x5b,0x4f,0x66,0x6d};
//个位:0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5
code uint8 LED_CODE2[] = {0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,
0x3f,0x3f,0x06,0x06,0x06,0x06,0x06,0x06};
//十位:0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1
uint8 KeyValue; //存放读取的键值
uint8 KeyState; //存放键的状态
void delay(uint16 x)
uint16 i,j;
for(i = x; i > 0; i --)
for(j = 114; j > 0; j --);
void Beep()
uint8 i;
for(i=0;i<100;i++)
delay(1);
P3 ^= 0x01;
void DigDisplay()
P2 = 0x01;
P0 = LED_CODE1[KeyValue];
delay(10);
P2 = 0x02;
P0 = LED_CODE2[KeyValue];
delay(10);
void KeyDown()
uint8 Tmp;
P1=0xf0; //对于并行口,不算赋值,是输出状态;
if(P1!=0xf0)
KeyState=1;
P1=0x0f;
Tmp = P1 ^ 0x0f; //检测低四位
switch(Tmp)
case 1: KeyValue = 0; break;
case 2: KeyValue = 1; break;
case 4: KeyValue = 2; break;
case 8: KeyValue = 3; break;
default: KeyValue = 16;
P1=0xf0;
Tmp = P1 >> 4 ^ 0x0f;//检测高四位
switch(Tmp)
case 1: KeyValue += 0; break;
case 2: KeyValue += 4; break;
case 4: KeyValue += 8; break;
case 8: KeyValue += 12;
while(P1!=0xf0);
Beep();
KeyState = 0;
KeyValue = 0;
KeyDown();
if(KeyState==1)
KeyState = 0;
DigDisplay();
所有资料51hei附件下载:
实验四.zip
(192.67 KB, 下载次数: 13)
2021-11-10 15:42 上传
点击文件名下载附件
下载积分: 黑币 -5
